[GRASS-stats] Converting an SpatialGridDataFrame to an imgdata object
S. Koukoulas (lists) sotkouklistes at gmail.com
Tue Feb 26 02:23:15 PST 2013
Perhaps what you need to look at, is how to Convert a
SpatialGridDataFrame to a matrix (or to an array if there are more than
one bands). It seems that biOps uses simple matrices/arrays for its
image objects. if you google it you should find some   responses to
earlier requests send to R-SIG-geo.
alternatively, you could import directly to biOps your image as tiff
from your system's disk space.
hth,
sotiris
On 02/24/2013 01:35 PM, Nikos Alexandris wrote:
> Hi stats-list!
> Are there instructions/examples out there on converting objects that have been
> read by readRAST6 to imgdata objects?
> I want to utilise the ImgIsodata function from the biOps package, perform an
> unsupervised clustering/classification and write back the result to a grass
> raster map.
> Thanks in advance, Nikos
> grass-stats mailing list
> grass-stats at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-stats
More information about the grass-stats mailing list
