[GRASS-stats] Converting an SpatialGridDataFrame to an imgdata object
Nikos Alexandris nik at nikosalexandris.net
Tue Feb 26 02:36:06 PST 2013
S. Koukoulas wrote:
> Perhaps what you need to look at, is how to Convert a
> SpatialGridDataFrame to a matrix (or to an array if there are more than
> one bands). It seems that biOps uses simple matrices/arrays for its
> image objects. if you google it you should find some   responses to
> earlier requests send to R-SIG-geo.
> alternatively, you could import directly to biOps your image as tiff
> from your system's disk space.
Thanks Sotiri,
once again, delivery deadlines approaching, and I froze it.  I was playing for
a while with conversions like the one you propose ( ...indeed, found many
relevant posts).
Note, doing it in a pure TIFF (that would likely loose its spatial reference
metadata) would require an additional step outside of R/GRASS to get the SRS
attached back in an identical, regarding the spatial resolution and extent,
TIFF. So as to get an GeoTIFF (again).
Thus,  I would prefer playing inside GRASS -> R -> GRASS only.
Thank you, Nikos
More information about the grass-stats mailing list
