[GRASS-stats] Some refactoring and fixing
Thomas Adams tea3rd at gmail.com
Wed Jan 28 06:55:27 PST 2015
Rainer,
Where can I get the new spgrass6 and spgrass7 to do some testing?
Thank you,
Tom
On Wed, Jan 28, 2015 at 7:23 AM, Rainer M Krug <Rainer at krugs.de> wrote:
> Rainer M Krug <Rainer at krugs.de> writes:
> > Roger Bivand <Roger.Bivand-aX1nC9UfZf8 at public.gmane.org> writes:
> >> On Tue, 27 Jan 2015, Rainer M Krug wrote:
> >>> Hi
> >>> I just committed a few of commits which refactor the code of readRAST,
> >>> writeRAST, readVECT & writeVECT by creating internal fi=unctions for
> >>> reading / writing for plugin / non-plugin and moving the default values
> >>> (get...Options()) into the function definitions.
> >> Good, thanks; I've updated the default values in the help files. It's
> >> easy to check for discrepancies in spgrass/pkg:
> >> R CMD build spgrass7
> >> R CMD check spgrass7_0.1-0.tar.gz
> > Thanks - haven't thought about about the check - will do the next time.
> >> Maybe we could quieten the progress bar in the output from checking?
> >> As in:
> >> pkg/spgrass7.Rcheck/spgrass7.Rout
> >> (local file, not added to repository, created by R CMD check if run in
> >> spgrass/pkg).
> >>> Also, I added tryCatch blocks to close open connections and to reset
> >>> echoCmdOption. I ran the examples before each commit and I did not see
> >>> any errors or changed behavior.
> >>> Apologies for the typos in the commit messages - I only saw them later.
> >>> To stick with consistency, I would recommend to rename the package to
> >>> spgrass7 and to look into the possibility to create a meta-package
> which
> >>> uses spgrass6 or spgrass7 (I don't know about the GRASS 5 interface -
> >>> haven't used it) depending on the GRASS GIS version set / loaded.
> >> I've renamed spgrass as spgrass7 - when you update, the change will
> >> propagate.
> > Thanks - got it.
> >> I'm unsure about a metapackage, maybe block version 7 in
> >> spgrass6 (following the parameter and flag name harmonisation).
> > Yes - spgrass6 for 6.x, spgrass7 for 7.x.
> > Will respnd in more detail tomorrow.
> OK - I just committed a blocking mechanism which for spgrass6 and
> spgrass7 so that they
> a) when R is started in GRASS, the package can not be loaded if the
> versions are not compatible and
> b) initGRASS raises an error if the GRASS GIS version in gisBase is not
> compatible with the package version
> If you think this is the right approach, the help files still need to be
> amended to reflect this change.
> I was thinking if it would make sense to introduce an overwrite
> mechanism for these checks to enable "non-standard" use or testing?
> I haven't looked at references for GRASS 7.0 in spgrass6 yet.
> Cheers,
> Rainer
> > Thanks,
> > Rainer
> >> Best wishes,
> >> Roger
> >>> Cheers,
> >>> Rainer
> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
> Biology, UCT), Dipl. Phys. (Germany)
> Centre of Excellence for Invasion Biology
> Stellenbosch University
> South Africa
> Tel :       +33 - (0)9 53 10 27 44
> Cell:       +33 - (0)6 85 62 59 98
> Fax :       +33 - (0)9 58 10 27 44
> Fax (D):    +49 - (0)3 21 21 25 22 44
> email:      Rainer at krugs.de
> Skype:      RMkrug
> PGP: 0x0F52F982
> grass-stats mailing list
> grass-stats at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-stats
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20150128/89acb498/attachment.html>
More information about the grass-stats mailing list
