[GRASS-stats] Some refactoring and fixing
Thomas Adams tea3rd at gmail.com
Wed Jan 28 08:55:04 PST 2015
Rainer,
Great — thank you!
Tom
On Wed, Jan 28, 2015 at 9:37 AM, Rainer M Krug <r.m.krug at gmail.com> wrote:
> Envoyé de mon iPhone
> Le 28 janv. 2015 à 15:55, Thomas Adams <tea3rd at gmail.com> a écrit :
> Rainer,
> Where can I get the new spgrass6 and spgrass7 to do some testing?
> The repository is on https://r-forge.r-project.org/projects/spgrass/   .
> It doesn't seem to be build yet so you have to install it from the svn
> repo or wait a few hours - then you shoud be able to install it via
>  *R install command: install.packages("spgrass6",
> repos="http://R-Forge.R-project.org <http://R-Forge.R-project.org>")*
>  Cheers,
> Rainer
> Thank you,
> Tom
> On Wed, Jan 28, 2015 at 7:23 AM, Rainer M Krug <Rainer at krugs.de> wrote:
>> Rainer M Krug <Rainer at krugs.de> writes:
>> > Roger Bivand <Roger.Bivand-aX1nC9UfZf8 at public.gmane.org> writes:
>> >> On Tue, 27 Jan 2015, Rainer M Krug wrote:
>> >>> Hi
>> >>> I just committed a few of commits which refactor the code of readRAST,
>> >>> writeRAST, readVECT & writeVECT by creating internal fi=unctions for
>> >>> reading / writing for plugin / non-plugin and moving the default
>> values
>> >>> (get...Options()) into the function definitions.
>> >> Good, thanks; I've updated the default values in the help files. It's
>> >> easy to check for discrepancies in spgrass/pkg:
>> >> R CMD build spgrass7
>> >> R CMD check spgrass7_0.1-0.tar.gz
>> > Thanks - haven't thought about about the check - will do the next time.
>> >> Maybe we could quieten the progress bar in the output from checking?
>> >> As in:
>> >> pkg/spgrass7.Rcheck/spgrass7.Rout
>> >> (local file, not added to repository, created by R CMD check if run in
>> >> spgrass/pkg).
>> >>> Also, I added tryCatch blocks to close open connections and to reset
>> >>> echoCmdOption. I ran the examples before each commit and I did not see
>> >>> any errors or changed behavior.
>> >>> Apologies for the typos in the commit messages - I only saw them
>> later.
>> >>> To stick with consistency, I would recommend to rename the package to
>> >>> spgrass7 and to look into the possibility to create a meta-package
>> which
>> >>> uses spgrass6 or spgrass7 (I don't know about the GRASS 5 interface -
>> >>> haven't used it) depending on the GRASS GIS version set / loaded.
>> >> I've renamed spgrass as spgrass7 - when you update, the change will
>> >> propagate.
>> > Thanks - got it.
>> >> I'm unsure about a metapackage, maybe block version 7 in
>> >> spgrass6 (following the parameter and flag name harmonisation).
>> > Yes - spgrass6 for 6.x, spgrass7 for 7.x.
>> > Will respnd in more detail tomorrow.
>> OK - I just committed a blocking mechanism which for spgrass6 and
>> spgrass7 so that they
>> a) when R is started in GRASS, the package can not be loaded if the
>> versions are not compatible and
>> b) initGRASS raises an error if the GRASS GIS version in gisBase is not
>> compatible with the package version
>> If you think this is the right approach, the help files still need to be
>> amended to reflect this change.
>> I was thinking if it would make sense to introduce an overwrite
>> mechanism for these checks to enable "non-standard" use or testing?
>> I haven't looked at references for GRASS 7.0 in spgrass6 yet.
>> Cheers,
>> Rainer
>> > Thanks,
>> > Rainer
>> >> Best wishes,
>> >> Roger
>> >>> Cheers,
>> >>> Rainer
>> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
>> Biology, UCT), Dipl. Phys. (Germany)
>> Centre of Excellence for Invasion Biology
>> Stellenbosch University
>> South Africa
>> Tel :       +33 - (0)9 53 10 27 44
>> Cell:       +33 - (0)6 85 62 59 98
>> Fax :       +33 - (0)9 58 10 27 44
>> Fax (D):    +49 - (0)3 21 21 25 22 44
>> email:      Rainer at krugs.de
>> Skype:      RMkrug
>> PGP: 0x0F52F982
>> grass-stats mailing list
>> grass-stats at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-stats
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20150128/4d904caa/attachment-0001.html>
More information about the grass-stats mailing list
