[GRASS-stats] R interface to grass 7.1
    Vaclav Petras
    wenzeslaus at gmail.com
    Thu Jun  4 11:44:12 PDT 2015
On Thu, Jun 4, 2015 at 12:43 PM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
> Hi,
> This is:
> http://trac.osgeo.org/grass/wiki/GSoC/2015#Neweasy-to-usecommandlineinterfaceforGRASSGIS
> is it? Did it get accepted - I don't see this on:
> http://www.google-melange.com/gsoc/org2/show/google/gsoc2015/osgeo
> and think that only improved metadata got funded. Do we know what the
> actual status is on this?
Hi Roger,
I can answer it :) I'm doing it simply because I need it (and I'm also
tired of solving the setup of environment variables over on over). However,
the GSoC idea went behind what I implemented. I implemented:
grass /path/to/mapset --exec r.external input=elevation.tiff
output=elevation
grass /path/to/mapset --exec r.univar map=elevation
Once conceptual questions are answered, it should be relatively simple to
add the following:
grass setmapset /path/to/mapset
grass run r.external input=elevation.tiff output=elevation
grass run r.univar map=elevation
The GSoC idea went much further:
grass execute r.univar map=file://elevation.tiff
* I used `execute` in the example, I'm not comfortable with the name but
the idea is to keep the names different for each interface to distinguish
the interfaces (but perhaps it is a wrong idea?). From discussion with
Rainer, I see that parameters won't cut it for shebang and there needs to
be a separate executable something like `grassscript`.
It would love to accommodate needs of the R interface. We just need to
figure out what they are.
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20150604/610217da/attachment.html>
More information about the grass-stats
