[GRASS-stats] R interface to grass 7.1
Rainer M Krug Rainer at krugs.de
Thu Jun 4 11:47:55 PDT 2015
Roger Bivand <Roger.Bivand at nhh.no> writes:
> Hi,
> This is:
> http://trac.osgeo.org/grass/wiki/GSoC/2015#Neweasy-to-usecommandlineinterfaceforGRASSGIS
> is it? Did it get accepted - I don't see this on:
> http://www.google-melange.com/gsoc/org2/show/google/gsoc2015/osgeo
> and think that only improved metadata got funded.
This is true as far as I know, but it seems that Vaclac took it in
his own hands to code the initial stages and he checked it into the
GRASS 7.1 source.
I installed GRASS 7.1 from source using homebrew (the formula is in a
pending pull request) and I could execute the examples fine.
> Do we know what the actual status is on this?
The
| grass71 MAPSET --exec THE GRASS COMAND WITH WHATEVER COMES NOW
is working, but I don't know if it has been tested a lot. For testing,
the sp collection could help as there are already examples which one
could run.
Otherwise - no idea - but it seems to be going forward.
> I'd feel that this could be a variant in rgrass7 if it becomes
> available,
Yes - some changes and getting rid of the initialisation of the GRASS
session, and only provide the path to the grass71 executable.
> but I'm not sure how it would expose the interface description.
--8<---------------cut here---------------start------------->8---
grass71 --exec g.list --interface-description
--8<---------------cut here---------------end--------------->8---
I just tried it out.
or, maybe safer,
grass71 PATH/TO/MAPSET --exec g.list --interface-description
This is only the first stage, and Vaclac seems to be very much open to
suggestions and discussion on which direction this should go.
The discussion is on grass-user.
It seems that you are planning to move the sp packages to github - is
this true?
Cheers,
Rainer
> Best wishes,
> Roger
> On Thu, 4 Jun 2015, Rainer M Krug wrote:
>> Hi
>> I guess you have seen the announcement from Vaclac Petras about the new
>> command line interface to R. This sounds very exciting and I would like
>> to start playing with the R-GRASS 7.1 interface. What would be the best
>> approach concerning git / svn? should I setup my own github for this or
>> should I slot in one of the spgrass repositories?
>> Thanks,
>> Rainer
>> http://permalink.gmane.org/gmane.comp.gis.grass.user/51680
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel :       +33 - (0)9 53 10 27 44
Cell:       +33 - (0)6 85 62 59 98
Fax :       +33 - (0)9 58 10 27 44
Fax (D):    +49 - (0)3 21 21 25 22 44
email:      Rainer at krugs.de
Skype:      RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20150604/a9312224/attachment.pgp>
More information about the grass-stats mailing list
