[GRASS-stats] Initiation Error: "dyld: Library not loaded" (rgrass7)
Benjamin Holland ben.holland at gmail.com
Thu Mar 5 11:57:21 PST 2015
Hi, Rainer,
I downloaded and installed Grass 7.0 (stable) from here:
http://grassmac.wikidot.com/downloads
Up until now, I've been using the Grass 7.0 GUI.
I'm using R version 3.1.2Installed rgrass7 with this
command: install.packages("rgrass7", repos="http://R-Forge.R-project.org",
type="source")
Here is the command I ran to initiate:
initGRASS(gisBase ='/Applications/GRASS-7.0.app/Contents/MacOS',
          location = 'test', mapset = 'test',
          gisDbase = '/Users/benholland/grassdata', override = TRUE)
The complete error message I received a few minutes ago:
dyld: Library not loaded:
/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/lib/libgrass_gis.7.0.0.dylib
  Referenced from: /Applications/GRASS-7.0.app/Contents/MacOS/bin/g.gisenv
  Reason: no suitable image found.  Did find:
/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/lib/libgrass_gis.7.0.0.dylib:
stat() failed with errno=13
When I open the Grass 7 GUI, there is a new location, so part of this code
is working. However, there is no mapset.
Thanks,
Ben
On Thu, Mar 5, 2015 at 12:46 PM, Rainer M Krug <r.m.krug at gmail.com> wrote:
> Envoyé de mon iPhone
> Le 5 mars 2015 à 19:39, Benjamin Holland <ben.holland at gmail.com> a écrit :
> Hi, all. After some research, I've seen that the dyld error is quite
> common. After successfully installing rgrass7 from source, I tried to
> initiate GRASS in R. This is my first time trying this, so I could be doing
> some things incorrectly. I'm running on OSX Yosemite.
> What is the exact error message?
> When do you get it?
> Which commands did you execute?
> How did you install grass, R, gdal, ... ?
> Which versions?
> More information is needed to provide any help.
> Cheers,
> Rainer
> I tried the troubleshooting suggestion on the grass wiki, but after
> establishing the link to /user/local/lib I'm still getting the same error.
> Does anyone have any suggestions?
> Thanks,
> Ben Holland
> grass-stats mailing list
> grass-stats at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-stats
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20150305/794a5fa8/attachment.html>
More information about the grass-stats mailing list
