[GRASS-stats] Error rgrass7 using readRAST()
Francesco Tonini ftonini84 at gmail.com
Wed Mar 18 08:42:06 PDT 2015
Roger,
Apparently the error was due to a mismatch with the default g.region.
After checking in GRASS for g.region -p I found that it was set to 100 x
101 columns. If any of you ever encounter the same problem, just make
sure to set the g.region using the same input raster of interest, i.e.
using g.region raster=/your_raster_name/.
Are there any plans to make use of the 'raster' package so that
readRAST() reads a 'raster' R obj instead of a sp griddataframe? Same
for writeRAST().
Thank you,
Francesco
On 3/18/2015 11:32 AM, Roger Bivand wrote:
> On Wed, 18 Mar 2015, Francesco Tonini wrote:
>> Dear all,
>> I am testing rgrass7 and trying to read a single raster file calling
>> R from GRASS. I am using the function readRAST(). Currently, this
>> return a SpatialGridDataFrame R object but it seems to have a bug
>> when reading the correct number of observations. In my case the input
>> raster is 100 x 100 so it should have 10,000 observations (ncell).
>> Instead, readRAST() read 100 x 101 with 10,100 observations. Did
>> anybody encounter this issue or know what it could be caused by?
>> I can send over my input raster if that helps to test on your machines.
> Please make an archive file of (parts of) your location, including all
> the upper-level files, but maybe excluding other data than the raster
> file in question. In the packaged location, the same problem should
> occur. Put the archive file somewhere from which it can be downloaded.
> I'll take a look.
> Roger
>> Any help is much appreciated.
>> Thank you.
>> Francesco
>> grass-stats mailing list
>> grass-stats at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-stats
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20150318/880991cd/attachment.html>
More information about the grass-stats mailing list
