[GRASS-stats] GRASS can't find R packages from personal library on Windows
Roger Bivand Roger.Bivand at nhh.no
Thu Nov 17 11:57:21 PST 2016
On Thu, 17 Nov 2016, Helmut Kudrnovsky wrote:
>> My Windows 7, GRASS 7.0.4 shows identical .libPaths() values both inside
>> and out with RGui. I don't know how the location of the personal library
>> folder is recorded - is it in the registry? How might one know? It looks
>> like:
>> Sys.getenv("R_LIBS_USER")
> tested within a winGRASS7.0.5 session:
> [1] "C:\\Users\\test/R/win-library/3.3"
>> .libPaths()
> [1] "C:/Program Files/R/R-3.3.1/library"
> R_LIBS_USER is listed there within the winGRASS session, but the path itself
> looks odd.
Unfortunately, I couldn't reproduce this with stand-alone GRASS 7.0.5 or
7.2, Windows 7 Pro, R 3.3.2. I see the same .libPaths() values inside and
outside. But see below - I found out how to reproduce the problem
predictably.
The reason was (of course) that I'd forgotten that I had set R_LIBS_USER
in Control Panel -> System and Security -> System -> Advanced system
settings -> Environment Variables. I'd done this as a response to the
extra work caused at each annual change of the default address as R's
version was incremented. See also:
https://stat.ethz.ch/R-manual/R-devel/library/base/html/libPaths.html
So a workaround might to use the R_LIBS_USER environment variable in that
setting, checking that the directory exists. R uses it internally as
generated, but doesn't export it. I don't know how this plays
cross-platform.
Best wishes,
Roger
> outside a winGRASS7.0.5/7.2.svn session, everthing is ok with these
> variables (see above).
> best regards
> Helmut
> View this message in context: http://osgeo-org.1560.x6.nabble.com/GRASS-can-t-find-R-packages-from-personal-library-on-Windows-tp5295771p5296239.html
> Sent from the Grass - Stats mailing list archive at Nabble.com.
> grass-stats mailing list
> grass-stats at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-stats
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; fax +47 55 95 91 00
e-mail: Roger.Bivand at nhh.no
http://orcid.org/0000-0003-2392-6140
https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
http://depsy.org/person/434412
More information about the grass-stats mailing list
