[GRASS-stats] GRASS can't find R packages from personal library on Windows
Roger Bivand Roger.Bivand at nhh.no
Thu Nov 17 23:53:47 PST 2016
On Thu, 17 Nov 2016, Roger Bivand wrote:
> On Thu, 17 Nov 2016, Helmut Kudrnovsky wrote:
>> >  My Windows 7, GRASS 7.0.4 shows identical .libPaths() values both inside
>> >  and out with RGui. I don't know how the location of the personal library
>> >  folder is recorded - is it in the registry? How might one know? It looks
>> >  like:
>> >  Sys.getenv("R_LIBS_USER")
>>  tested within a winGRASS7.0.5 session:
>>  [1] "C:\\Users\\test/R/win-library/3.3"
>> >  .libPaths()
>>  [1] "C:/Program Files/R/R-3.3.1/library"
>>  R_LIBS_USER is listed there within the winGRASS session, but the path
>>  itself
>>  looks odd.
> Unfortunately, I couldn't reproduce this with stand-alone GRASS 7.0.5 or 7.2,
> Windows 7 Pro, R 3.3.2. I see the same .libPaths() values inside and outside.
> But see below - I found out how to reproduce the problem predictably.
> The reason was (of course) that I'd forgotten that I had set R_LIBS_USER in
> Control Panel -> System and Security -> System -> Advanced system settings ->
> Environment Variables. I'd done this as a response to the extra work caused
> at each annual change of the default address as R's version was incremented.
> See also:
> https://stat.ethz.ch/R-manual/R-devel/library/base/html/libPaths.html
> So a workaround might to use the R_LIBS_USER environment variable in that
> setting, checking that the directory exists. R uses it internally as
> generated, but doesn't export it. I don't know how this plays cross-platform.
In a context with Windows 7 without setting the R_LIBS_USER environment
variable, R outside GRASS reports:
> Sys.getenv("HOME")
[1] "C:\\Users\\rsb\\Documents"
> .libPaths()
[1] "C:/Users/rsb/Documents/R/win-library/3.3"
[2] "C:/Program Files/R/R-3.3.2/library"
but inside GRASS %HOME% is re-defined, so:
> Sys.getenv("HOME")
[1] "C:\\Users\\rsb"
> .libPaths()
[1] "c:/Program Files/R/R-3.3.2/library"
as R cannot construct: subdirectory ‘R/win-library/x.y’ of the home
directory, for R x.y.z, because "C:\\Users\\rsb/R/win-library/x.y" does
not exist, and that is where R is looking (here in GRASS):
[1] "C:\\Users\\rsb/R/win-library/3.3"
(the different dirseps do not matter).
Does WinGRASS need to change the HOME environment variable? If it does,
users of R in GRASS need to set R_LIBS or R_LIBS_USER, easiest once via
Control Panel.
Roger
> Best wishes,
> Roger
>>  outside a winGRASS7.0.5/7.2.svn session, everthing is ok with these
>>  variables (see above).
>>  best regards
>>  Helmut
>>  View this message in context:
>>  http://osgeo-org.1560.x6.nabble.com/GRASS-can-t-find-R-packages-from-personal-library-on-Windows-tp5295771p5296239.html
>>  Sent from the Grass - Stats mailing list archive at Nabble.com.
>>  _______________________________________________
>>  grass-stats mailing list
>>  grass-stats at lists.osgeo.org
>>  http://lists.osgeo.org/mailman/listinfo/grass-stats
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; fax +47 55 95 91 00
e-mail: Roger.Bivand at nhh.no
http://orcid.org/0000-0003-2392-6140
https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
http://depsy.org/person/434412
More information about the grass-stats mailing list
