[GRASS-stats] GRASS can't find R packages from personal library on Windows
Helmut Kudrnovsky hellik at web.de
Fri Nov 18 04:16:08 PST 2016
Helmut Kudrnovsky wrote
> I had a look into the sources; I can't find a line of code where winGRASS
> changes %HOME% at the moment; but it obvious uses %USERPROFILE% as %HOME%.
maybe just found it:
for trunk
https://trac.osgeo.org/grass/browser/grass/trunk/lib/init/grass.py#L712
712	def ensure_home():
713	    """Set HOME if not set on MS Windows"""
714	    if windows and not os.getenv('HOME'):
715	        os.environ['HOME'] = os.path.join(os.getenv('HOMEDRIVE'),
716	                                          os.getenv('HOMEPATH'))
and for the 7.0.x-line
https://trac.osgeo.org/grass/browser/grass/branches/releasebranch_7_0/lib/init/grass.py#L1338
1338	# set HOME
1339	if windows and not os.getenv('HOME'):
1340	    os.environ['HOME'] = os.path.join(os.getenv('HOMEDRIVE'),
1341	                                      os.getenv('HOMEPATH'))
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/GRASS-can-t-find-R-packages-from-personal-library-on-Windows-tp5295771p5296458.html
Sent from the Grass - Stats mailing list archive at Nabble.com.
More information about the grass-stats mailing list
