[GRASS-stats] GRASS can't find R packages from personal library on Windows
Roger Bivand Roger.Bivand at nhh.no
Fri Nov 18 04:22:20 PST 2016
>> I had a look into the sources; I can't find a line of code where winGRASS
>> changes %HOME% at the moment; but it obvious uses %USERPROFILE% as %HOME%.
> maybe just found it:
> for trunk
> https://trac.osgeo.org/grass/browser/grass/trunk/lib/init/grass.py#L712
> 712	def ensure_home():
> 713	    """Set HOME if not set on MS Windows"""
> 714	    if windows and not os.getenv('HOME'):
> 715	        os.environ['HOME'] = os.path.join(os.getenv('HOMEDRIVE'),
> 716	                                          os.getenv('HOMEPATH'))
> and for the 7.0.x-line
> https://trac.osgeo.org/grass/browser/grass/branches/releasebranch_7_0/lib/init/grass.py#L1338
> 1338	# set HOME
> 1339	if windows and not os.getenv('HOME'):
> 1340	    os.environ['HOME'] = os.path.join(os.getenv('HOMEDRIVE'),
> 1341	                                      os.getenv('HOMEPATH'))
OK, so the extension would be to look in %HOME%/Documents to see if there
is %HOME%/Documents/R, and if so do what? If R_LIBS_USER is set, do
nothing, if not, set R_USER, or guess which win-library is the relevant
one and set R_LIBS_USER? Even if this is redundant for non-R users?
Roger
> best regards
> Helmut
> View this message in context: http://osgeo-org.1560.x6.nabble.com/GRASS-can-t-find-R-packages-from-personal-library-on-Windows-tp5295771p5296458.html
> Sent from the Grass - Stats mailing list archive at Nabble.com.
> grass-stats mailing list
> grass-stats at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-stats
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; fax +47 55 95 91 00
e-mail: Roger.Bivand at nhh.no
http://orcid.org/0000-0003-2392-6140
https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
http://depsy.org/person/434412
More information about the grass-stats mailing list
