[GRASS-stats] GRASS can't find R packages from personal library on Windows
Helmut Kudrnovsky hellik at web.de
Wed Nov 23 13:07:20 PST 2016
>>> both changes should be discussed on the dev ML.
>>> before such changes are implemented, the workaround to manage this issue
>>> manually via the control panel should go to the wiki.
>>> Anna, any suggestions?
>> just opened a discussion on the dev ML:
>> https://lists.osgeo.org/pipermail/grass-dev/2016-November/083122.html
> some insights regarding %HOME% in winGRASS:
> https://lists.osgeo.org/pipermail/grass-dev/2016-November/083159.html
> [GRASS-dev] does GRASS need HOME to be defined?
>> >> anyone more insight, if %HOME% is needed in winGRASS?
>> >Done by Glynn in:
>> >https://trac.osgeo.org/grass/changeset/37873
>> any hints?
> It's used G__home() on Unix (and as a fallback on Windows) and it's
> used for G_rc_path() on Windows (for some reason, the Unix version
> uses getpwuid(), which is probably incorrect in this context).
> It may also be used implicitly by library functions or external
> programs looking for configuration files.
> https://lists.osgeo.org/pipermail/grass-stats/2016-November/001708.html
> OK, so the extension would be to look in %HOME%/Documents to see if there
> is %HOME%/Documents/R, and if so do what? If R_LIBS_USER is set, do
> nothing, if not, set R_USER, or guess which win-library is the relevant
> one and set R_LIBS_USER? Even if this is redundant for non-R users?
> so it's still to discuss what would be the best option to overcome this
> issue.
tested here within a winGRASS session:
D:\software_source\grass_trunk\mswindows\external\rbatch>set
R_USER=C:\Users\hkmyr\Documents
D:\software_source\grass_trunk\mswindows\external\rbatch>R
R version 3.3.1 (2016-06-21) -- "Bug in Your Hair"
Copyright (C) 2016 The R Foundation for Statistical Computing
Platform: x86_64-w64-mingw32/x64 (64-bit)
R ist freie Software und kommt OHNE JEGLICHE GARANTIE.
Sie sind eingeladen, es unter bestimmten Bedingungen weiter zu verbreiten.
Tippen Sie 'license()' or 'licence()' für Details dazu.
R ist ein Gemeinschaftsprojekt mit vielen Beitragenden.
Tippen Sie 'contributors()' für mehr Information und 'citation()',
um zu erfahren, wie R oder R packages in Publikationen zitiert werden
können.
Tippen Sie 'demo()' für einige Demos, 'help()' für on-line Hilfe, oder
'help.start()' für eine HTML Browserschnittstelle zur Hilfe.
Tippen Sie 'q()', um R zu verlassen.
> .libPaths()
[1] "C:/Users/hkmyr/Documents/R/win-library/3.3"
[2] "C:/Program Files/R/R-3.3.1/library"
if we let %HOME% untouched, the easiest way may be
(similar as we already do it with Rstudio:
IF EXIST "%ProgramFiles%\RStudio\bin\rstudio.exe" set
PATH=%PATH%;%ProgramFiles%\RStudio\bin)
- check if there is C:\Users\yourusername\Documents\R
- if yes, set R_USER=C:\Users\hkmyr\Documents
so the most common cases of private R libraries should be covered.
any comments/objections for this change?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/GRASS-can-t-find-R-packages-from-personal-library-on-Windows-tp5295771p5297192.html
Sent from the Grass - Stats mailing list archive at Nabble.com.
More information about the grass-stats mailing list
