[GRASS-stats] rgrass7 - SQLite and GML drivers not working for readVECT
Helmut Kudrnovsky hellik at web.de
Tue Oct 10 12:21:41 PDT 2017
>Are SQLite and GML drivers disabled/broken in readVECT? I only get
driver="ESRI Shapefile" to work,
confirmed by:
> sessionInfo()
R version 3.4.0 (2017-04-21)
Platform: x86_64-w64-mingw32/x64 (64-bit)
Running under: Windows 10 x64 (build 15063)
Matrix products: default
locale:
[1] C
attached base packages:
[1] stats     graphics  grDevices utils     datasets  methods   base
other attached packages:
[1] rgrass7_0.1-9 XML_3.98-1.9  sp_1.2-5
loaded via a namespace (and not attached):
[1] compiler_3.4.0  rgdal_1.2-12    grid_3.4.0      lattice_0.20-35
only driver="ESRI Shapefile" works here.
trying SQLite:
> bla5 <- readVECT("firestations", driver="SQLite")
Supported formats:
Error: driver %in% candDrivers is not TRUE
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Stats-f4049448.html
More information about the grass-stats mailing list
