[GRASS-stats] rgrass7 - SQLite and GML drivers not working for readVECT
Roger Bivand Roger.Bivand at nhh.no
Wed Oct 11 01:59:45 PDT 2017
Thanks for trying to contribute. The GH site is not the rgrass7
development site - that is SVN on R-forge (GH is a very preliminary trial
site for using sf vector representation in R, and maybe raster raster
representation (or forthcoming stars), instead of sp classes).
GRAS 7.2.2 works OK with the current logic checks; I can reproduce the
issue in 7.3 (latest); there is a change in vector/v.in.ogr/main.c
returning the DriverLongName for GDAL >= 2.0; in GRASS 7.2.2, there is no
such change. Could the GRASS developer responsible for this obvious
regression provide an additional flag in v.in.ogr (and v.external,
v.out.ogr) to permit backwards compatibility? See line 387, needs to
change
#if GDAL_VERSION_NUM >= 2000000
to add a !backwards_compatible test too.
I'll hold off trying to fix this in rgrass7 because it is a regression. I
can add the backwards_compatibility=TRUE flag to readVECT() once it is
exposed.
This is:
https://trac.osgeo.org/grass/ticket/3425
Roger
On Tue, 10 Oct 2017, Ahmadou Dicko wrote:
> In the readVECT function, internally v.in.ogr is used to list the supported
> vector format and it is compared the format available using rgdal (or sf).
> However, using v.external instead of v.in.ogr fix this single problem
> because of the way the output is different (in form).
> For example, if you use v.in.ogr you will have to compare  SQLite_/_Spatialite
> (GRASS) to SQLite (R) and they are not the same.
> I tried to send a PR, let me know if it works
> https://github.com/rsbivand/rgrass7/pull/1
> Best,
> On Tue, Oct 10, 2017 at 9:29 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
>>> Gesendet: Dienstag, 10. Oktober 2017 um 23:24 Uhr
>>> Von: "Ahmadou Dicko" <dicko.ahmadou at gmail.com>
>>> An: "Helmut Kudrnovsky" <hellik at web.de>
>>> Cc: "Roger Bivand" <Roger.Bivand at nhh.no>, "grass-stats at lists.osgeo.org" <
>> grass-stats at lists.osgeo.org>
>>> Betreff: Re: [GRASS-stats] rgrass7 - SQLite and GML drivers not working
>> for readVECT
>>> Hi everyone,
>>> I think that using v.external -f (instead of v.in.ogr -f) can fix this
>> issue (didn't try yet)
>>> execGRASS("v.external", flags = "f", intern = TRUE)
>>> [1] "ARCGEN"         "AVCBin"         "AVCE00"
>>> [4] "AeronavFAA"     "AmigoCloud"     "BNA"
>>> [7] "CAD"            "CSV"            "CSW"
>>> [10] "Carto"          "Cloudant"       "CouchDB"
>>> [13] "DGN"            "DXF"            "EDIGEO"
>>> [16] "ESRI_Shapefile" "ElasticSearch"  "GFT"
>>> [19] "GML"            "GPKG"           "GPSBabel"
>>> [22] "GPSTrackMaker"  "GPX"            "GeoJSON"
>>> [25] "GeoRSS"         "Geoconcept"     "Geomedia"
>>> [28] "HTF"            "HTTP"           "Idrisi"
>>> [31] "JML"            "JPEG2000"       "KML"
>>> [34] "MSSQLSpatial"   "MapInfo_File"   "Memory"
>>> [37] "MySQL"          "ODBC"           "ODS"
>>> [40] "OGR_GMT"        "OGR_GRASS"      "OGR_PDS"
>>> [43] "OGR_SDTS"       "OGR_VRT"        "OSM"
>>> [46] "OpenAir"        "OpenFileGDB"    "PCIDSK"
>>> [49] "PDF"            "PGDUMP"         "PGeo"
>>> [52] "PLSCENES"       "PostgreSQL"     "REC"
>> in a quick check, there is no difference in available formats.
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; e-mail: Roger.Bivand at nhh.no
Editor-in-Chief of The R Journal, https://journal.r-project.org/index.html
http://orcid.org/0000-0003-2392-6140
https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
More information about the grass-stats mailing list
