[GRASS-stats] rgrass7 - SQLite and GML drivers not working for readVECT
Helmut Kudrnovsky hellik at web.de
Fri Oct 20 12:31:04 PDT 2017
>Please try:
>install.packages("rgrass7", repos="http://R-Forge.R-project.org")
>which incorporates the change in both places, not just one as before (svn
>revision 63 on R-Forge, spgrass project).
tested with above install.packages cmd:
> sessionInfo()
R version 3.4.0 (2017-04-21)
Platform: x86_64-w64-mingw32/x64 (64-bit)
Running under: Windows 10 x64 (build 15063)
Matrix products: default
locale:
[1] C
attached base packages:
[1] stats     graphics  grDevices utils     datasets  methods   base
other attached packages:
[1] rgrass7_0.1-11 XML_3.98-1.9   sp_1.2-5
loaded via a namespace (and not attached):
[1] compiler_3.4.0  grid_3.4.0      lattice_0.20-35
it works here on winGRASS.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Stats-f4049448.html
More information about the grass-stats mailing list
