[GRASS-stats] rgrass7 - SQLite and GML drivers not working for readVECT
Veronica Andreo veroandreo at gmail.com
Sat Oct 21 06:15:40 PDT 2017
Yup, works now. Thanks Roger! And thanks MarkusM as well! :)
best,
vero
2017-10-20 21:31 GMT+02:00 Helmut Kudrnovsky <hellik at web.de>:
> >Please try:
> >install.packages("rgrass7", repos="http://R-Forge.R-project.org")
> >which incorporates the change in both places, not just one as before (svn
> >revision 63 on R-Forge, spgrass project).
> tested with above install.packages cmd:
> > sessionInfo()
> R version 3.4.0 (2017-04-21)
> Platform: x86_64-w64-mingw32/x64 (64-bit)
> Running under: Windows 10 x64 (build 15063)
> Matrix products: default
> locale:
> [1] C
> attached base packages:
> [1] stats     graphics  grDevices utils     datasets  methods   base
> other attached packages:
> [1] rgrass7_0.1-11 XML_3.98-1.9   sp_1.2-5
> loaded via a namespace (and not attached):
> [1] compiler_3.4.0  grid_3.4.0      lattice_0.20-35
> it works here on winGRASS.
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Stats-f4049448.html
> grass-stats mailing list
> grass-stats at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-stats
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20171021/7c56f78a/attachment.html>
More information about the grass-stats mailing list
