[GRASS translations] RE: Portuguese translation
Markus Neteler neteler at itc.it
Fri Dec 10 09:06:11 EST 2004
Hi Eduardo,
to translate the GRASS 5.7 documentation, please download the
source code (latest!! best from CVS to keep in sync) and to
take the files 'description.html'. The translated files
(then called 'description_pt_BR.html' for example) we should
insert into the CVS for future maintenance.
Anything else would get outdated quickly or lost.
In general all GRASS 5.7 modules (should) have such a file,
however, we are continuously updating them. Translators should
be aware of that and take care to keep the translated files
updated as well.
Let me suggest to start with a few important pages. Then
we (me?) will have to extend the HTML/MAN page creation engine
to take care of integrating well the translated pages upon compile
time.
Please note that the header/footer/parameters/flags section is
generated *automatically* while everything below the
DESCRIPTION section is maintained manually. So: no need to translate
the first part with parameters and flags. This will appear translated
automatically once the messages in the C code got translated (po files).
But this requires changes in the C code which are (slowly) done
by programmers/contributors.
Summary: Yes, please translate the manual pages. To do so, the
module related 'description.html' files have to be translated.
Best is to use an ASCII editor to avoid that messy HTML code
get's inserted which won't be properly translated to MAN format
later.
Thanks
 Markus
On Fri, Dec 10, 2004 at 10:33:12AM -0200, Eduardo Patto Kanegae wrote:
> Hi,
> I checked up the link http://grass.itc.it/i18n.html but sound it talks only about translation of *.po files . I'm interested on translating GRASS documentation ( man pages? any others ?) and have GRASS 5.7 installed.
> Can I just translate *.html of man pages to a new "pt_BR" directory? or should I translate another source of files?
> Does the man pages that comes with 5.7 is ideal for that, or should I pick up another version?
> And how not to translate the same of anyone has already done?
> best regards,
> http://www.webmapit.com.br
> ICQ: 303747254
> Treinamento em UMN MapServer - http://www.webmapit.com.br/ptbr/?menuoption=mapserver
> Fórum MapServer Brasil - http://mapserver.cttmar.univali.br/forum
> ***Fim da Mensagem / End of Message ***
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
More information about the grass-translations mailing list
