arc coverages to grass
Daniel Rodriguez danr at rsgis3.tamu.edu
Thu Dec 17 12:44:45 EST 1992
	Would converting ARC/INFO coverages into a dlg format be an easy way
of reading files into grass4.0? One question, does the attributes for the
ARC/INFO coverages have to be change into majors and minor codes in the dlg
process and if it does what is the proper way of changing the attributes into
Major and Minor codes.
			Thank you;
				Daniel H. Rodriguez    danR at rsgis3.tamu.edu
			        Texas A&M University     (409) 845-9425
		 	          RS/GIS laboratory    fax (409) 845-9425
			      Forest Science Department
			   College Station Texas, 77843-2135
