A Christmas offering
Ronald E. Thomas
ront at niwot.CFNR.ColoState.EDU
Thu Dec 17 14:51:57 EST 1992
Hello GRASSusers:
There have been a lot of questions coming in to the list lately
that have been previously answered. It is possible to get the archived
copies of the GRASSusers and GRASSprogramers lists from
lists-owner at moon.cecer.army.mil . It requires a little work ( uncompress,
vi & delete header, cat the sections together, uudecode & optionally delete
extraneous header lines).
Well, the work has been done for you (by me) and placed on the moon
at /grass/incoming. The files grassp-mail and grassu-mail are ASCII text
files of the entire programmers and users lists from the inception until
30 Nov., with most of the header material edited out. The grassu-mail file
is 1.8meg, the grassp-mail file < 1meg.
I've gotten a lot of great advise through the lists, and hope that
these files will help newer subscribers answer some questions that seem to
pop up frequently.
Of course, in order for them to work you'll have to 'ftp' them and
USE them.
A simple script file using "grep -i -n" can search the file for a
command/function of interest, returning the line # and text where the
command/function is found. You can then use "more" or "vi -R" to access the
file and see what has already been asked and/or answered. I hope some of
you find this helpful.
MERRY CHRISTMAS
Ronald Thomas ^ ront at meeker.cfnr.colostate.edu
Natural Resource Spec. (GIS) ^
Resource Management Division ^ Phone: 303-586-3565 x285
Rocky Mountain National Park ^ 700-323-7285 (FTS)
Estes Park, CO 80517 ^
rom grass-lists-owner at max.cecer.army.mil Thu Dec 17 13:51:40 1992
Received: from zorro.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1)
id AA19134; Thu, 17 Dec 92 13:51:40 CST
Received: from amber.cecer.army.mil by zorro.cecer.army.mil with SMTP id AA22674
(5.67a/IDA-1.4.4 for <grassu-people at amber>); Thu, 17 Dec 1992 13:51:38 -0600
Return-Path: <cashman at crsa.bu.edu>
Received: from max.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1)
id AA19128; Thu, 17 Dec 92 13:51:35 CST
Received: from CRSA.BU.EDU by max.cecer.army.mil with SMTP id AA10260
(5.67a/IDA-1.5 for <grassu-list at max.cecer.army.mil>); Thu, 17 Dec 1992 13:51:35 -0600
Received: from NILE.BU.EDU by crsa.bu.edu (5.61+++/Spike-2.1)
id AA07323; Thu, 17 Dec 92 14:51:33 -0500
Received: by nile.bu.edu (5.61+++/Spike-2.1)
id AA12546; Thu, 17 Dec 92 14:51:36 -0500
Date: Thu, 17 Dec 92 14:51:36 -0500
Message-Id: <9212171951.AA12546 at nile.bu.edu>
Sender: lists-owner at max.cecer.army.mil
Reply-To: grassu-list at max.cecer.army.mil
Precedence: Bulk
Subject: Re: v.support on digitized data
Hi Daphne,
I have seen a lot of these messages in my time. What it
means is that the labels that you assigned to the polygons
got attatched to the wrong polygon. In the first case:
Warning: area 141 label: 205 matched another label 205
it's no worry because the same label was attatched, though
this polygon may have two labels and some other polygon none.
In the second case:
Warning: area 143 label: 201 matched another label 205
you will have to go in and correct the label.
I think that this happens because of polygons
that are too small, or the label is too close to the
edge of the polygon, or some small troll enjoys making
our lives miserable.
Good Luck!
pamela cashman
Open GRASS Foundation
