r.in.sunrast / memory leaks
Michael Shapiro
shapiro at zorro.cecer.army.mil
Fri Sep 18 16:42:18 EDT 1992
r.in.sunrast has been upgraded for 4.1 to (1) deal with this
requirement for the correct number of cols and (2) to accept bit
images as well. I will try to get the new version on moon soon.
As for memory leaks, GRASS is FULL of them. Even if this program
freed the memory allocated by G_malloc() there are many places in
GRASS where memory leaks occur. For example, a subroutine may
return a pointer to a character string. This pointer may point to
allocated memory or it may point to static memory. The
documentation doesn't say this. So programmers don't have
complete control on freeing all memory used by GRASS except to
rely on program exit to clean up. Un fortunately it would be a
big effort to get rid of many of these leaks so it probably won't
happen.
Does anyone know of a Unix system that doesn't return allocated
memory to the system? (This isn't meant to be a cynical question).
|Helpful suggestions for the fix to r.in.sunrast have been offered
|by :
|Jim Hinthorne,
|Director GIS Lab
|Central Wash. Univ.
|He pointed out that :
|Two more changes are needed to make this program bullit-pruff.
|1. The parameter passed to G_malloc should be ncol_fix, not ncols,
|because this is the size of the record to read later.
|2. Before the final "return 1;" there should be "free (raster);" so
|that the space allocated by G_malloc will be freed up. Some systems
|are good about doing this automatically when the program exits, but
|some aren't so friendly and the programmer should take responsibility
|for freeing allocated memory.
|So, the new fix to r.in.sunrast would be :
|cd src.alpha/raster/r.in.sunrast/cmd
|and edit main.c
|replace the function rasttocell with :
|rasttocell (rast_fd, cell_fd, nrows, ncols)
| unsigned char *raster;
| CELL *cell;
| int row, col, ncol_fix ;
| /* check if row is even or odd */
| ncol_fix = ncols;
| if ( ncols % 2 )
| ncol_fix += 1 ;
| cell = G_allocate_cell_buf();
| /* JH fix 1 */
| raster = (unsigned char *) G_malloc(ncol_fix);
| if (verbose)
| fprintf (stderr, "complete ... ");
| for (row = 0; row < nrows; row++)
| if (verbose)
| G_percent (row, nrows, 2);
| if (read (rast_fd, raster, ncol_fix) != ncol_fix)
| return -1;
| for (col = 0; col < ncols; col++)
| cell[col] = (CELL) raster[col];
| if (G_put_map_row (cell_fd, cell) < 0)
| exit(1);
| if (verbose)
| /* JH Fix 2 */
| free (raster);
| return 1;
|and recompile
|Thanks, Jim
|Bob Courtney
|Atlantic Geoscience Centre
Michael Shapiro U.S. Army CERL
email: shapiro at zorro.cecer.army.mil Environmental Division
phone: (217) 373-7277 P.O. Box 9005
fax: (217) 373-7222 Champaign, Ill. 61826-9005
