Installing GRASS4.0 on an SGI workstation?
    wes at msc.edu
    wes at msc.edu
    Wed Feb 17 17:12:03 EST 1993
Hello,
I am trying to install GRASS4.0 on an SGI 4D/35TG workstation.  When I
run the "GISGEN" command, I get a lot of prototype errors that look like
this:
        cc -O  -I/work/i1a/GRASS4.0/src/libes -DUSE_TERMIO -c V_tty.c
accom: Error: V_tty.c, line 39: prototype parameter 2 type must have all qualifiers of actual arg (except`outermost`) and pointed to types must be compatible (ANSI 3.3.2.2,3.3.16.1)
           tstp_old = (int (*)()) signal(21     ,       ((SIG_PF)1) ); signal(21        ,tstp_old) ;
accom: Error: V_tty.c, line 39: Argument 2 Type Doesn't Match prototype description; prototype:  pointer to function returning void is different from actual:  pointer to function returning int
Assuming that GRASS4.0 is supposed to build properly on an SGI 4D workstation,
does anyone have the src/CMD/head/head file that contains the proper flags for
this?
Thanks.
      o o o o o o o . . .   ________________________________ _____=======_T___
    o      _____           ||Wes Barris                    | | wes at msc.edu   |
  .][__n_n_|DD[  ====|____  |Research Equipment Inc. dba   | |(612) 626-8090 |
 >(________|__|_[___/_____]_|Minnesota_Supercomputer_Center|_|_FAX: 626-1596_|_
 _/oo OOOOOO o`  ooo   ooo  'o^o^o                    o^o^o` 'o^o         o^o`
A programming language is low-level when its programs require attention to the irrelevant.
