Exporting SGI graphics?
wes at msc.edu wes at msc.edu
Wed Feb 17 17:36:03 EST 1993
[]Also, once you convert rgb images to ppm, you can use pnm-plus tools or
[]xv, a public domain image viewer/enhancer.
One thing that all should be aware of is that xv is an 8 bit tool.  Even
if you read in a 24 bit image (which is commonly generated on an SGI), xv
will convert it to 8 bits-colormapped.  When it is saved, you will have
an 8 bit file, not a 24 bit file.
      o o o o o o o . . .   ________________________________ _____=======_T___
    o      _____           ||Wes Barris                    | | wes at msc.edu   |
  .][__n_n_|DD[  ====|____  |Research Equipment Inc. dba   | |(612) 626-8090 |
 >(________|__|_[___/_____]_|Minnesota_Supercomputer_Center|_|_FAX: 626-1596_|_
 _/oo OOOOOO o`  ooo   ooo  'o^o^o                    o^o^o` 'o^o         o^o`
A programming language is low-level when its programs require attention to the irrelevant.
