Problems with data using V.DIGIT
Darrell McCauley mccauley at ecn.purdue.edu
Wed Nov 3 12:03:06 EST 1993
Brian Culpepper (brian at cast.uark.edu ) writes on 3 Nov 93:
>I once had a similar problem, and it turned out to be "double-lines".
>That is to say, they overlapped perfectly....Ouch! You also mentioned
in which case v.spag may be a big help
