Help :Window width
Malcolm Williamson malcolm at cast.uark.edu
Fri Feb 11 10:19:42 EST 1994
I assume that you are running XGRASS. You can overcome at least part of the
problem by starting a GRASS shell and using the g.manual or g.help commands
from there instead.
> As a fresh Grass user I consider the information in the
> help on Grass topics area and the on line user's manual
> as useful. But one problem with these functions is that
> the output is given in windows where the window width is
> smaller than the width of the lines in the explanations
> that are given. This pakes the process of reading a bit
> hard, because i have to scroll the the messages horisontally
> for each line I read. So now I wonder if anyone knows how
> to change the window width, or how the make letters in the
> dialog window smaller to solve this problem.
> Thanks
Malcolm D. Williamson - Research Assistant       E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-6159
Ozark Rm. 12                                        Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
