site.to.vector.to.rast
Richard Beecham beecham at aerg.canberra.edu.au
Mon Jun 6 20:18:07 EDT 1994
Cliff
Here is what I did.
	1. v.support
	2. v.digit - close polygons by breaking lines and snapping in the
                     edit menu, and then labelling the areas.
	3. v.to.rast
Richard Beecham                               email:beecham at aerg.canberra.edu.au
Hydrology Unit                                phone:(02) 895 7169
NSW Department of Water Resources             fax  :(02) 895 7834
Parramatta NSW 2124
Australia
On Mon, 6 Jun 1994, Cliff Behrens wrote:
> I would like to build a raster layer from valued site data after using the
> s.voronoi option in geom to generate polygons around each site.  So far,
> my approach has been to:
> 1)  create an ASCII site file with category values and labels.
> 2)  use s.in.ascii to convert it to a GRASS site list.
> 3)  apply the voronoi tesselation in geom to the site list to produce
>     the vector layer.
> Now, how can I produce a raster layer that assigns a site's value to all of
> the cells contained within that site's polygon?
> Thanks in advance for your help,
> Cliff Behrens
