Removing dead lines from vector files
Brian Culpepper brian at cast.uark.edu
Tue Mar 8 09:08:37 EST 1994
>      I have several VERY large vector files composed of "patched" elevation
> files that have been modified to the point that there are a large number of
> dead lines in them. I used v.clean on them but got an out of memory error
> message. This brings me to the question. I know the files are in the dig_att
> portion of GRASS, but how can I distinguish a dead line from a line that is
> supposed to remain. That is, what is the marker or lack of marker that
> identifies the dead line from a active line? I am planning on using a UNIX
> command to remove the offending lines and then running v.support to remake the
> topology.
> Thanks in advance...
> Chris D Garvin: Ft Sill, OKLAHOMA
Chris,
I believe the "dead" lines will have the lower case letter ( l, a, p) before the
attribute's geographic location (x,y coord.) in the dig_att directory.
BTW, Do you know Maj. Jim Carafano? I recently sent him some Digital Elevation
data, and I was wondering if he had received it.  Just wondering......
Have a good day,
R. Brian Culpepper                                 Research Assistant
Center for Advanced Spatial Technologies           (fax) 501 575-3846
Rm. 214 Ozark Hall                                (work) 501 575-6159
University of Arkansas                            brian at cast.uark.edu
Fayetteville, AR 72701
All opinions are my own and do not necessarily reflect those of the
Center for Advanced Spatial Technologies or the University of Arkansas.
