v.support WARNING message
Agustin Lobo alobo at ija.csic.es
Wed Jan 17 07:00:00 EST 1996
What does the following message means?
Does it mean that the label of area 244 (which is 273)
is the same that the label of area 274?
v.support usos.proj_v
   V.SUPPORT:
Selected information from vector header
 Organization:
 Map Name:      usos_v
 Source Date:
 Orig. Scale:   0
 No snapping will be done
    Reading Vector file.
 100%
    Building areas
    Building islands
    Attaching labels
WARNING: area 10116 label: 1 matched another label: 258.
WARNING: area 244 label: 273 matched another label: 274.
WARNING: area 9981 label: 4200 matched another label: 4213.
 Number of lines:   27150
 Number of nodes:   18291
 Number of areas:   10116
 Number of isles:   1257
 Number of atts :   10115
 Number of unattached atts :   0
 Snapped lines  :   0
Thanks
Agus
Dr. Agustin Lobo
Instituto de Ciencias de la Tierra (CSIC)
Marti Franques s/n
08028 Barcelona (Spain)
tel. 34 3 330 2716
fax. 34 3 411 0012
alobo at eno.princeton.edu
