Need help importing DEM data
Bill Brown brown at gis.uiuc.edu
Wed Mar 20 07:00:00 EST 1996
James,
Looks OK to me, except when you get to the r.in.ll, you have to
use the correct corner for your data.  The SW corner for the
las_vegas-e data would be: 36N,115W
>r.in.ll input=las_vegas-e.dem output=dem.utm dimension=1201,1201 \
>bpc=2 res=3,3 corner=sw,34N,119W spheroid=wgs72
>g.region rast=dem.utm
Also, you should ALWAYS do a d.erase after a g.region change!
>d.rast dem.utm
- Bill
