Too many raster files open
Justin Hickey jhickey
Fri Jun 13 05:05:32 EDT 1997
Bill and Michael,
On Jun 12,  2:50pm, William L. Baker wrote:
> No one had a remedy, but someone did point out where the
> message comes from, but now when I look I see that I've lost that
> information.
I have a copy of the reply to Bill's posting from Dec 19, 1996 I include the
entire message below.
Hope this helps.
On Dec 20, 12:18pm, Martin Ameskamp wrote:
> Subject: Re: too many open raster files
> > Any grass programmers still left out there?
> 	Sure.
> > I get "WARNING: too many open raster files" after about
> > 20 iterations of a dynamic simulation model that uses
> > r.mapcalc and other GRASS programs, as well as some
> > contributed code.  If I omit the following subroutine in
> > our contributed code, then the program does not produce this
> > error, so this is the offending code, although other things
> > going on elsewhere could be contributing other open
> > raster files (?):
> 	There are two aspects to this problem (I think). The first is
> 	the origin of the warning. This warning is produced in
> 	file src/libes/gis/opencell.c if you try to open more than
> 	MAXFILES files. MAXFILES is a constant that is #defined to be
> 	30 in src/libes/gis/G.h
> 	I don't know why it's 30, probably the programmers thought that
> 	nobody in their right mind would need more than 30 open files
> 	anyawy (sounds vaguely familiar...).
> 	So I guess you could change this constant and recompile GRASS
> 	(you'd probably need to recompile or at least relink just about
> 	all of GRASS since this is a fairly central point).
> 	The second aspect is that your use of more than 30 open files
> 	_may_ point to a resource leakage. On the other hand, a complex
> 	mapcalc calculation could easily lead to a large number
> 	of temporary files (I don't know what mapcalc does in main-memory
> 	and where it uses temp files; a look at the code might help there).
> 	If your program is a complex one that opens and closes raster files
> 	all over the place, a debugger might help. Set breakpoints in
> 	the relevant routines (G_open_cell etc., recompile them with
> 	debugging information if necessary) and check if close
> 	is called often enough etc.
> 	Finally, I only use G_gisinit at the beginning of my GRASS programs
> 	(mostly in main()). Calling it in a subroutine makes sense if that
> 	routine is the only one that uses GRASS code, but calling it
> 	more than once might have funny effects on some bookkeeping
> 	details, maybe including file descriptors.
> 	Good luck,  Martin
> > void probascii();
> >     int fd;
> >     char *mapset;
> >     static char prog_name[] = "probascii";
> >     static char filename[] = "DISTPROB";
> >     G_gisinit(prog_name);
> >     if((mapset = G_find_cell(filename,"")) == NULL) {
> >       printf("Unable to find file %s.\n",filename);
> >       exit(1);
> >     if((fd = G_open_cell_old(filename, mapset)) < 0) {
> >       printf("Unable to open file %s.\n",filename);
> >       exit(-1);
> >    ...CODE OMITTED
> >     G_close_cell(fd);
> > I didn't write this code, but I'm trying to debug it.
> > Anyone see why this fails to close the raster files?
> > Or, any other clues as to what else could be
> > producing this WARNING?
> > Bill Baker
> > BAKERWL at UWYO.EDU
> Martin Ameskamp, Inst. f. Informatik I (Computing Dept.)
> Kiel University, Olshausenstr. 40, 24118 Kiel, Germany
> Fax: ++49 431 8804054, Voice: ++49 431 8804474,
> ma at informatik.uni-kiel.de, URL http://www.informatik.uni-kiel.de/~ma/
>-- End of excerpt from Martin Ameskamp
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
