grass prompt
Conn Copas conn.copas at dsto.defence.gov.au
Mon Jul 13 01:56:58 EDT 1998
Francois Delclaux <francois.delclaux at mpl.orstom.fr> writes:
> I'm working with several mapsets in the same database, and sometimes
> I don't know what is the current mapset and the current search path.
> It's quite easy to set the prompt to the current mapset in the GIS.sh
> start up file, but after
> the prompt is always the same, even if I work in another mapset.
> A solution is to write a script wich modifies the prompt according to
> the
> current mapset and search path and to execute this script manualy.
> But I would like to have an automaticaly updated prompt .
Well I am looking at the Grass prompt, and it displays the current _mapset_,
but not the current _search path_. The quickest way of displaying the search
path is to define an alias for a new 'g.mapsets' command, and put it somewhere
appropriate like $GISRC.cshrc, eg:
set prompt = "GRASS 4.2 > "
alias g.maps '$GISBASE/bin/g.mapsets mapset=\!*; echo "Mapset <${MAPSET}> in Location <${LOCATION_NAME}> with Search-Path <\!*>"'
Usage: g.maps mapset1[,mapset2...]
The slower solution is of course to hack the g.mapsets code.
