IDRISI ascii format import
Kamarul Azlan Mohd Nasir kamarul at fka.utm.my
Tue Nov 24 04:44:11 EST 1998
Hi there,
I am interested in obtaining the tool you mentioned, that is to convert arc info
.e00 format in to Grass format. Hope youcan send me the tools that you
mentioned.
Thanks in advance for your cooperation.
> I finally found a tool to convert e00 format ARC/INFO files to
> something more usable (ECV2000 tool. Runs only on Win through :(
> Now, how do I get the info from the resulting IDRISI .dvc and .vec into
> Grass? I read that IDRISI binary .img files can be used directly, but what
> about these ascii files?
> There is a v.out.idrisi module that will produce exactly the same format
> (.dvc & .vec) in an idrisi directory of the current mapset. But there is
> no corresponding v.in.idrisi.
> So there must be a simple solution, only I haven't found it. So I ask.
> regards
> MHu
Kamarul
Dept. of Civil Engr
UTM
07-5576160 ext 3026
