tcltkgrass errors
arch. Stefano Maffulli stefano.maffulli at DPMPE.UNIFI.IT
Mon Aug 16 09:48:35 EDT 1999
It is becoming a torment :-)
I am using a Sun SparcStation20 running Solaris 2.6, under CDE.  I
downloaded from linuxapps a small scientific calculator (MoCalc)
developed in TclTk. I downloaded and installed it as normal user, not
root, and it works.
So it has to be something related to tcltkgrass, right?
I am clueless now.  What else can it be?  Is there any Solaris user out
there that can give some advice?
thank you
stefano maffulli
Markus Neteler wrote:
> Hi Stefano,
> well, what platform are you using? I guess there is somewere
> an error with permission. The tcltkgrass is very friendly, it
> does not write anything as far as I know.
> Perhaps you try another tcl/tk software if it works. You need
> an application using tcl/tk 8.0 (comparing to tcltkgrass).
> Perhaps then you find the problem.
> tcltksoftware you may find there: www.linuxapps.com
> Cheers
>  Markus
