More worries after Re:New GIS.sh (bash shell/GRASS problem)
Alan Eugene Davis adavis at netpci.com
Sun Jan 24 06:26:00 EST 1999
The new GIS.sh you provided does start up, but I cannot get permissions for
display :0.0 when running d.mon.  I removed the locks in
locks/<machinename., no difference.  Is there another set of locks?
I will go to the list archive.  I"ve seen a number of problems there.
In grass, when I run "set" (using bash) I am indeed the user who started the
display.
GIS.sh is owned by grass.grass.
Alan Davis
> ---559023410-851401618-917109770=:10056
> Content-type: text/plain; charset="us-ascii"
> Hi,
> I have changed the etc/GIS.sh file to fix the bash problem
> (there was no GRASS modules access due to path problems).
> When you have such a problem, replace the GIS.sh file
> in grass42/etc with the attached file (please make savety
> copy of the original file). You can find it also on
> GRASS 4.2.1 faq:
>   http://www.geog.uni-hannover.de/grass/grass_faq.html
> I have added a "bash" section to GIS.sh, and tested it on
> SuSe 5.3/bash.
> Hope this helps
>    Markus Neteler
> Content-type: TEXT/PLAIN; charset="US-ASCII"; name="GIS.sh"
> Content-transfer-encoding: BASE64
> Content-ID: <Pine.SOL.3.96.990123164250.10056B at hgeo02.geog.uni-hannover.de>
> Content-Description: store in grass/etc/
> OiAke0dJU0JBU0U/fQ0KDQojIGdldCBob21lIGRpcmVjdG9yeSwgbmFtZSBv
> ZiBsb2NrZmlsZSBhbmQgZ2lzcmMgZmlsZQ0KDQpob21lPWBjZDtwd2RgDQps
> b2NrZmlsZT0kaG9tZS8uZ2lzbG9jaw0KR0lTUkM9JGhvbWUvLmdyYXNzcmMN
> CmV4cG9ydCBHSVNSQw0KDQojIHNldCB0aGUgR0lTX0xPQ0sgdmFyaWFibGUg
> dG8gY3VycmVudCBwcm9jZXNzIGlkDQoNCkdJU19MT0NLPSQkDQpleHBvcnQg
> R0lTX0xPQ0sNCg0KIyBzZXQgUEFUSCB0byBHUkFTUyBiaW4sIEVUQyB0byBH
> UkFTUyBldGMNCg0KRVRDPSRHSVNCQVNFL2V0Yw0KUEFUSD0kR0lTQkFTRS9i
> aW46JEdJU0JBU0Uvc2NyaXB0czokR0lTQkFTRS9nYXJkZW4vYmluOiRQQVRI
> DQpleHBvcnQgUEFUSA0KDQojIGNoZWNrIGZvciBjb25jdXJyZW50IHVzZQ0K
> DQokRVRDL2xvY2sgJGxvY2tmaWxlICQkDQpjYXNlICQ/IGluDQogMCkgOzsN
> CiAxKQ0KICAgIGVjaG8gYHdob2FtaWAgaXMgY3VycmVudGx5IHJ1bm5pbmcg
> R1JBU1MuIENvbmN1cnJlbnQgdXNlIG5vdCBhbGxvd2VkLg0KICAgIGV4aXQg
> OzsNCiAqKQ0KICAgIGVjaG8gVW5hYmxlIHRvIHByb3Blcmx5IGFjY2VzcyAk
> bG9ja2ZpbGUNCiAgICBlY2hvIFBsZWFzZSBub3RpZnkgc3lzdGVtIHBlcnNv
> bmVsLg0KICAgIGV4aXQgOzsNCmVzYWMNCg0KIyBmaXJzdCB0aW1lIHVzZXIg
> Li4uDQoNCmlmIFsgISAtZiAkR0lTUkMgXQ0KdGhlbg0KCWNhdCAkRVRDL2dp
> c19pbnRybw0KCWVjaG8gIiINCgllY2hvICJIaXQgUkVUVVJOIHRvIGNvbnRp
> bnVlIg0KCXJlYWQgYW5zDQpmaQ0KDQojIHVzZXIgc2VsZWN0cyBMT0NBVElP
> TiBhbmQgTUFQU0VUDQoNCiRFVEMvZ2lzX3NldA0KY2FzZSAkPyBpbg0KIDAp
> IDs7DQogKikgZXhpdCA7Ow0KZXNhYw0KDQojIHVuc2V0IHRoZSBNT05JVE9S
> IHZhcmlhYmxlIHRvIGZvcmNlIHVzZXIgdG8gc2VsZWN0IG9uZSBpZiB0aGV5
> IGFyZSBnb2luZw0KIyB0byBkbyBncmFwaGljcy4NCg0KZy5naXNlbnYgTU9O
> SVRPUj0NCg0KIyBnZXQgZ2lzcmMgaW50byB0aGUgZW52aXJvbm1lbnQNCg0K
> ZXZhbCBgZy5naXNlbnZgDQoNCkxPQ0FUSU9OPSR7R0lTREJBU0U/fS8ke0xP
> Q0FUSU9OX05BTUU/fS8ke01BUFNFVD99DQpleHBvcnQgTE9DQVRJT04NCg0K
> aWYgWyAteCAkaG9tZS8uZ3Jhc3NyYy40LjIuMSBdDQp0aGVuDQoJJGhvbWUv
> LmdyYXNzcmMuNC4yLjENCmVsaWYgWyAteCAkR0lTQkFTRS9ncmFzc3JjIF0N
> CnRoZW4NCgkkR0lTQkFTRS9ncmFzc3JjDQpmaQ0KIyMjIyMjIyMjIyMjIyMj
> IyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMj
> IyMNCg0KdHJhcCAiIiAyIDMNCg0Kc2g9ImBiYXNlbmFtZSAkU0hFTExgIg0K
> Y2FzZSAiJHNoIiBpbg0KICAgIGtzaCkgIHNoZWxsbmFtZT0iS29ybiBTaGVs
> bCI7Ow0KICAgIGNzaCkgIHNoZWxsbmFtZT0iQyBTaGVsbCIgOzsNCiAgICB0
> Y3NoKSBzaGVsbG5hbWU9IlRDIFNoZWxsIiA7Ow0KICAgIGJhc2gpIHNoZWxs
> bmFtZT0iQmFzaCBTaGVsbCIgOzsNCiAgICBzaCkgICBzaGVsbG5hbWU9IkJv
> dXJuZSBTaGVsbCI7Ow0KICAgICopICAgIHNoZWxsbmFtZT1zaGVsbDs7DQpl
> c2FjDQoNCiMgRGlzcGxheSB0aGUgYWR2ZXJ0aXNpbmcNCmNsZWFyDQpjYXQg
> PDwgRU9GDQpXZWxjb21lIHRvIEdSQVNTIDQuMi4xIChWLjIwIC0gRGVjZW1i
> ZXIgMTk5OCkgDQoNCkdlb2dyYXBoaWMgUmVzb3VyY2VzIEFuYWx5c2lzIFN1
> cHBvcnQgU3lzdGVtIChHUkFTUykgaXMgYSBUcmFkZW1hcmsNCm9mIFUuUy4g
> QXJteSBDb25zdHJ1Y3Rpb24gRW5naW5lZXJpbmcgUmVzZWFyY2ggTGFib3Jh
> dG9yaWVzIChVU0FDRVJMKQ0KYW5kIEJheWxvciBVbml2ZXJzaXR5IEdSQVNT
> IFJlc2VhcmNoIEdyb3VwLg0KDQpUaGlzIG5ldyByZWxlYXNlIG9mIEdSQVNT
> IGlzIGNvb3JkaW5hdGVkIGFuZCBwcm9kdWNlZCBieSB0aGUgR1JBU1MNClJl
> c2VhcmNoIEdyb3VwIGF0IEJheWxvciBVbml2ZXJzaXR5IHdpdGggYXNzaXN0
> YW5jZSBmcm9tIHRoZSBPZmZpY2UNCm9mIEdSQVNTIEludGVncmF0aW9uIChP
> R0kpIGxvY2F0ZWQgYXQgVVNBQ0VSTC4NCg0KDQpUaGlzIHZlcnNpb24gcnVu
> bmluZyB0aHJ1IHRoZSAkc2hlbGxuYW1lICgkU0hFTEwpDQpIZWxwIGlzIGF2
> YWlsYWJsZSB3aXRoIHRoZSBjb21tYW5kOiBnLmhlbHANCldoZW4gcmVhZHkg
> dG8gcXVpdCBlbnRlcjogICAgICAgICAgIGV4aXQNCkVPRg0KDQpjYXNlICIk
> c2giIGluDQoNCmNzaHx0Y3NoKQ0KICAgIEhPTUU9JExPQ0FUSU9ODQogICAg
> ZXhwb3J0IEhPTUUNCiAgICBjc2hyYz0kSE9NRS8uY3NocmMNCiAgICB0Y3No
> cmM9JEhPTUUvLnRjc2hyYw0KICAgIHJtIC1mICRjc2hyYyAkdGNzaHJjDQog
> ICAgZWNobyAic2V0IGhvbWUgPSAkaG9tZSIgPiAkY3NocmMNCiAgICBlY2hv
> ICJzZXQgaGlzdG9yeSA9IDMwIG5vY2xvYmJlciBpZ25vcmVlb2YiID4+ICRj
> c2hyYw0KDQogICAgZWNobyAic2V0IHByb21wdCA9ICdcXCIgPj4gJGNzaHJj
> DQogICAgZWNobyAiTWFwc2V0IDwke01BUFNFVH0+IGluIExvY2F0aW9uIDwk
> e0xPQ0FUSU9OX05BTUV9PiBcXCIgPj4gJGNzaHJjDQogICAgZWNobyAiR1JB
> U1MgNC4yLjEgPiAnIiA+PiAkY3NocmMNCiAgICBlY2hvICdzZXQgQk9HVVM9
> YGA7dW5zZXQgQk9HVVMnID4+ICRjc2hyYw0KDQogICAgaWYgWyAtciAkaG9t
> ZS8uZ3Jhc3MuY3NocmMgXQ0KICAgIHRoZW4NCgljYXQgJGhvbWUvLmdyYXNz
> LmNzaHJjID4+ICRjc2hyYw0KICAgIGZpDQoNCiAgICBpZiBbIC1yICRob21l
> Ly5jc2hyYyBdDQogICAgdGhlbg0KCWdyZXAgJ14gKnNldCAgKm1haWwgKj0g
> KicgJGhvbWUvLmNzaHJjID4+ICRjc2hyYw0KICAgIGZpDQoNCiAgICBpZiBb
> IC1yICRob21lLy50Y3NocmMgXQ0KICAgIHRoZW4NCglncmVwICdeICpzZXQg
> ICptYWlsICo9IConICRob21lLy50Y3NocmMgPj4gJGNzaHJjDQogICAgZmkN
> Cg0KICAgIGlmIFsgLXIgJGhvbWUvLmxvZ2luIF0NCiAgICB0aGVuDQoJZ3Jl
> cCAnXiAqc2V0ICAqbWFpbCAqPSAqJyAkaG9tZS8ubG9naW4gPj4gJGNzaHJj
> DQogICAgZmkNCg0KICAgIGVjaG8gInNldCBwYXRoID0gKCAkUEFUSCApICIg
> fCBzZWQgJ3MvOi8gLydnID4+ICRjc2hyYw0KDQogICAgY3AgJGNzaHJjICR0
> Y3NocmMNCiAgICAkRVRDL3J1biAkU0hFTEwNCg0KICAgIEhPTUU9JGhvbWUN
> CiAgICBleHBvcnQgSE9NRQ0KICAgIDs7DQoNCmJhc2gpDQogICAgSE9NRT0k
> TE9DQVRJT04gICAgICAjIHNhdmUgLmJhc2hyYyBpbiAkTE9DQVRJT04NCiAg
> ICBleHBvcnQgSE9NRQ0KICAgIGJhc2hyYz0kSE9NRS8uYmFzaHJjDQogICAg
> cm0gLWYgJGJhc2hyYw0KICAgIGVjaG8gInRlc3QgLXogJFBST0ZJTEVSRUFE
> ICYmIC4gL2V0Yy9wcm9maWxlIiA+ICRiYXNocmMNCiAgICBlY2hvICJ0ZXN0
> IC1lIH4vLmFsaWFzICYmIC4gfi8uYWxpYXMiID4+ICRiYXNocmMNCiAgICBl
> Y2hvICJ1bWFzayAwMjIiID4+ICRiYXNocmMNCg0KICAgIGlmIFsgLXIgJGhv
> bWUvLmdyYXNzLmJhc2hyYyBdDQogICAgdGhlbg0KCWNhdCAkaG9tZS8uZ3Jh
> c3MuYmFzaHJjID4+ICRiYXNocmMNCiAgICBmaQ0KDQogICAgZWNobyAiZXhw
> b3J0IFBBVEg9JFBBVEgiID4+ICRiYXNocmMNCg0KICAgICRFVEMvcnVuICRT
> SEVMTA0KDQogICAgSE9NRT0kaG9tZQ0KICAgIGV4cG9ydCBIT01FDQogICAg
> OzsNCg0KKikNCg0KUFMxPSINCk1hcHNldCA8JE1BUFNFVD4gaW4gTG9jYXRp
> b24gPCRMT0NBVElPTl9OQU1FPg0KR1JBU1MtR1JJRCA+ICINCg0KICAgIGV4
> cG9ydCBQUzENCg0KICAgICRFVEMvcnVuICRTSEVMTA0KICAgIDs7DQplc2Fj
> DQoNCnRyYXAgMiAzDQojIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMj
> IyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjDQojIHVuc2V0IHRoZSBN
> T05JVE9SIHZhcmlhYmxlDQoNCm1vbml0b3I9YGcuZ2lzZW52IE1PTklUT1Jg
> DQppZiBbICIkbW9uaXRvciIgXQ0KdGhlbg0KCSRFVEMvbW9uLnJlbGVhc2Ug
> LXYgJG1vbml0b3INCmZpDQpnLmdpc2VudiBNT05JVE9SPQ0KDQojIFJlYWQg
> Z2lzcmMgYWdhaW4NCg0KZXZhbCBgZy5naXNlbnZgDQpMT0NBVElPTj0ke0dJ
> U0RCQVNFP30vJHtMT0NBVElPTl9OQU1FP30vJHtNQVBTRVQ/fQ0KDQoNCiMg
> ZXhpdCBzZXNzaW9uLiByZW1vdmUgdW53YW50ZWQgZmlsZXMNCg0KY2xlYXIN
> CmVjaG8gIiINCmVjaG8gIkdSQVNTIFNFU1NJT04gV1JBUFVQIg0KZWNobyAi
> Ig0KDQplY2hvICJZb3UgaGF2ZSBqdXN0IGZpbmlzaGVkIHdvcmtpbmcgb24g
> bWFwc2V0OiA8JE1BUFNFVD4iDQplY2hvICIiDQoNCmFueT1ubw0KZGlyPSRM
> T0NBVElPTi9jZWxsDQp0eXBlPVJBU1RFUg0KY291bnQ9MA0KaWYgWyAtZCAk
> ZGlyIF0NCnRoZW4NCiAgICBjb3VudD1gbHMgJGRpciB8IHdjIC1sYA0KZmkN
> CmlmIFsgJGNvdW50ICE9IDAgXQ0KdGhlbg0KICAgIGFueT15ZXMNCiAgICBl
> Y2hvICIiDQogICAgZWNobyAiVGhlIGZvbGxvd2luZyAkdHlwZSBtYXBzIGJl
> bG9uZyB0byBpdDoiDQogICAgbHMgLUMgJGRpciB8IGF3ayAne3ByaW50ICIg
> IiAkMH0nDQogICAgZWNobyAiIg0KZWxzZQ0KICAgIGVjaG8gIlRoZXJlIGFy
> ZSBubyAkdHlwZSBtYXBzIGluIHRoaXMgbWFwc2V0Ig0KZmkNCg0KZGlyPSRM
> T0NBVElPTi9kaWcNCnR5cGU9VkVDVE9SDQpjb3VudD0wDQppZiBbIC1kICRk
> aXIgXQ0KdGhlbg0KICAgIGNvdW50PWBscyAkZGlyIHwgd2MgLWxgDQpmaQ0K
> aWYgWyAkY291bnQgIT0gMCBdDQp0aGVuDQogICAgYW55PXllcw0KICAgIGVj
> aG8gIiINCiAgICBlY2hvICJUaGUgZm9sbG93aW5nICR0eXBlIG1hcHMgYmVs
> b25nIHRvIGl0OiINCiAgICBscyAtQyAkZGlyIHwgYXdrICd7cHJpbnQgIiAi
> ICQwfScNCiAgICBlY2hvICIiDQplbHNlDQogICAgZWNobyAiVGhlcmUgYXJl
> IG5vICR0eXBlIG1hcHMgaW4gdGhpcyBtYXBzZXQiDQpmaQ0KDQpkaXI9JExP
> Q0FUSU9OL3NpdGVfbGlzdHMNCnR5cGU9U0lURVMNCmNvdW50PTANCmlmIFsg
> LWQgJGRpciBdDQp0aGVuDQogICAgY291bnQ9YGxzICRkaXIgfCB3YyAtbGAN
> CmZpDQppZiBbICRjb3VudCAhPSAwIF0NCnRoZW4NCiAgICBhbnk9eWVzDQog
> ICAgZWNobyAiIg0KICAgIGVjaG8gIlRoZSBmb2xsb3dpbmcgJHR5cGUgbWFw
> cyBiZWxvbmcgdG8gaXQ6Ig0KICAgIGxzIC1DICRkaXIgfCBhd2sgJ3twcmlu
> dCAiICIgJDB9Jw0KICAgIGVjaG8gIiINCmVsc2UNCiAgICBlY2hvICJUaGVy
> ZSBhcmUgbm8gJHR5cGUgbWFwcyBpbiB0aGlzIG1hcHNldCINCmZpDQoNCmVj
> aG8gIiINCmlmIFsgJE1BUFNFVCAhPSBQRVJNQU5FTlQgXQ0KdGhlbg0KICAg
> ICRHSVNCQVNFL2V0Yy9lY2hvIC1uICJTaGFsbCB0aGUgbWFwc2V0IDwkTUFQ
> U0VUPiBiZSBzYXZlZD8geS9uIFt5XSINCiAgICByZWFkIGFucw0KZWxzZQ0K
> ICAgIGFucz1ZRVMNCmZpDQoNCmNhc2UgJGFucyBpbg0KICAgIG58bm98TnxO
> T3xObykNCgllY2hvICIiDQoJZWNobyAiV0FSTklORyAtIGlmIHlvdSByZW1v
> dmUgeW91ciBtYXBzZXQsIHlvdSB3aWxsIGxvc2UiDQoJZWNobyAiICAgICAg
> ICAgIGFsbCB5b3VyIGRhdGEgZmlsZXMgaW4gdGhpcyBtYXBzZXQiDQoJZWNo
> byAiIg0KCSRHSVNCQVNFL2V0Yy9lY2hvIC1uICJhcmUgeW91IHN1cmUgeW91
> IHdhbnQgdG8gcmVtb3ZlIHlvdXIgbWFwc2V0PyB5L24gW25dIg0KCXJlYWQg
> YW5zDQoJY2FzZSAkYW5zIGluDQoJICAgIHl8eWVzfFl8WUVTfFllcykNCgkJ
> ZWNobyAiIg0KCQllY2hvICJSZW1vdmluZyBNQVBTRVQgJE1BUFNFVCINCgkJ
> cm0gLXJmICRMT0NBVElPTg0KCQlpZiBbIC1kICRMT0NBVElPTiBdDQoJCXRo
> ZW4NCgkJICAgIGVjaG8gIldBUk5JTkc6IFVuYWJsZSB0byBjb21wbGV0ZWx5
> IHJlbW92ZSAkTE9DQVRJT04iDQoJCWVsc2UNCgkJICAgIGVjaG8gIk1BUFNF
> VCAtLSRNQVBTRVQtLSBSRU1PVkVELiINCgkJZmkNCgkJc2xlZXAgMyA7Ow0K
> CSAgICAqKSA7Ow0KCSAgICBlc2FjDQoJICAgIDs7DQoNCiAgICAqKQ0KCWlm
> IFsgJGFueSA9IHllcyBdDQoJdGhlbg0KCSAgICBlY2hvICIiDQoJICAgICRH
> SVNCQVNFL2V0Yy9lY2hvIC1uICJEbyB5b3Ugd2lzaCB0byBzZWxlY3RpdmVs
> eSByZW1vdmUgZGF0YSBmaWxlcz8geS9uIFtuXSINCgkgICAgcmVhZCBhbnMN
> CgkgICAgY2FzZSAkYW5zIGluDQoJCXl8eWVzfFl8WUVTfFllcykgDQoJCSAg
> ICAkR0lTQkFTRS9iaW4vZy5yZW1vdmUgIDs7DQoJCSopIDs7DQoJICAgIGVz
> YWMNCglmaQ0KCSgkRVRDL2NsZWFuX3RlbXAgPiAvZGV2L251bGwgJikNCmVz
> YWMNCmNsZWFyDQplY2hvICIiDQplY2hvICIiDQplY2hvICIiDQplY2hvICIg
> ICAgICAgICAgICAgICAgICBHT09EIEJZRSBmcm9tIEdSQVNTIg0Kcm0gLWYg
> JGxvY2tmaWxlDQplY2hvICIiDQplY2hvICIiDQo=
> ---559023410-851401618-917109770=:10056--
Alan E. Davis                       Marianas High School (Science Department)
AAA196, Box 10001    adavis at netpci.com   http://www.saipan.netpci.com/~adavis
Saipan, MP  96950    15.16oN 145.7oE    GMT+10       Northern Mariana Islands
