[GRASSLIST:2349] Problems with projection conversion of vector files
anne-claire serres anne-claire.serres at thales-is.com
Thu Aug 16 13:11:23 EDT 2001
Hello !
I am using the v.proj command in order to convert a vector map that is
in lat, long with the
lambert conical conform projection.
So the 'first' location is in lat, long and the 'second' location is a
projection of the same area.
>From the 'second' location, I use the v.proj command and the map is
converting (positive
message).
I select the 'vector display' and choose the projected map: the map is
'displayed' ( positive
message) but it doesn't appear in the monitor. Why ?
Thank you very much !
Anne-Claire
Type: text/x-vcard
Desc: Carte pour anne-claire serres
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20010816/d0447931/anne-claire.serres.vcf
