[GRASSLIST:1492] RE: r3.showdspf
Markus Neteler neteler at geog.uni-hannover.de
Thu Feb 22 15:05:56 EST 2001
On Thu, Feb 22, 2001 at 09:57:15AM +0100, Johansen Mona wrote:
> Thanks for your answer!
> We have installed Mesa-widgets and solved the problem with the: libGLw.so.3.
> Now we are asked aboute a new library: libXm.so.1. What do this library
> belong to?
You need the "lesstif" (MOTIF clone) to be installed as well.
> And are there any other dependencies???
Please check:
 http://www.geog.uni-hannover.de/grass/grass5/
 (bottom of page)
 -> List of further (partly optional) requirements
I have just added this link.
Cheers
 Markus
> Regards,
> Mona
> -----Original Message-----
> From: Venkatesh Raghavan [mailto:raghavan at media.osaka-cu.ac.jp]
> Sent: Thursday, February 22, 2001 1:50 AM
> To: Johansen Mona
> Subject: Re: [GRASSLIST:1460] r3.showdspf
> Hi Mona
> Regarding the g3d compilation I had to compile the
> mesa widgets to create the libMesaGLw.a libMesaGLwM.a
> libraries. Moved these libraries to /usr/lib and
> added them to the OGLLIB in the
> src.contrib/GMSL/g3d/src3d/raster/r3.showdspf.openGL/Gmakefile
> as shown below;
> OGLLIB=-lGL -lGLw -lMesaGLw -lMesaGLwM ${LGLWM} -lXm -lX11 -lXt -lXext
> Subsequently the g3d including r3.showdspf.openGL could also be
> compiled without a hitch.
> Mesa widgets source code is available with the Mesa code and
> will generate the required libraries when compiled.
> Hope this helps.
> Raghavan
> > Hello,
> > I use the r3.showdspf to display isosurfaces previously calculated
> > with r3.mkdspf. I get the error message "error in loading shared
> libraries:
> > libGLw.so.3".
> > After installing Mesa, the same error occures.
> > Mona
Markus Neteler *  University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494  Fax: -3984
