[GRASSLIST:2698] Re: animation question
Markus Neteler neteler at itc.it
Tue Nov 27 12:58:29 EST 2001
On Tue, Nov 27, 2001 at 05:38:53PM +0000, Kevin Slover wrote:
> this is probably a stupid question, but I have to ask...I have created a
> script in NVIZ as done in the tutorial...
> which gives me many *.rgb files.  I would like to animate these rgb
> files...but can't seem to figure out how to go about doing that...
> also,  is there a way to edit the script to export the images as .bmp or
> some other format??  Just a curiousity question...
> thanks
Kevin,
have a look at
http://grass.itc.it/nviz/index.html
 -> mpeg_encode software: mpegparam.txt
It uses the netpbm tool "sgitopnm" to generate an MPEG stream
which reads the RGB format (RGB=SGI).
Hope this helps,
 Markus
