[GRASSLIST:2701] Re: animation question
Eric G. Miller egm2 at jps.net
Tue Nov 27 22:04:06 EST 2001
On Tue, 27 Nov 2001 18:58:29 +0100
Markus Neteler <neteler at itc.it> wrote:
> On Tue, Nov 27, 2001 at 05:38:53PM +0000, Kevin Slover wrote:
> > this is probably a stupid question, but I have to ask...I have created a
> > script in NVIZ as done in the tutorial...
> > which gives me many *.rgb files.  I would like to animate these rgb
> > files...but can't seem to figure out how to go about doing that...
> > also,  is there a way to edit the script to export the images as .bmp or
> > some other format??  Just a curiousity question...
> > thanks
> Kevin,
> have a look at
> http://grass.itc.it/nviz/index.html
>  -> mpeg_encode software: mpegparam.txt
> It uses the netpbm tool "sgitopnm" to generate an MPEG stream
> which reads the RGB format (RGB=SGI).
There are two ways to do animations in NVIZ, one give you an option of
a few different file types...
Eric G. Miller <egm2 at jps.net>
