[GRASSLIST:3285] Re: Topmodel parameter file
Glynn Clements glynn.clements at virgin.net
Mon Mar 4 10:11:40 EST 2002
Wouter Buytaert wrote:
> >  The TOPMODEL code is very good and topinx has the multiple flow
> > algorithm
> >  which works nicely on hillslopes (too bad that you cannot get the
> > upslope
> >  area too from it), so it would be nice if somebody could take it, add
> >  additional useful outputs and write decent manual.
> >  Perhaps we find someone to write an improved manual page including an
> >  example (eventually based on the parameter files in the source code)?
> Well, if I can get it working, it will be a pleasure to write an
> improved manual. However, until now, there are some major problems I
> encounter:
> - A "topographic index statistics file" is necessary as input. However,
> the original TOPMODEL program doesn't need such a file. So I really
> don't know what it would be.
> - In my Mac OS X pre3 version, the r.water.outlet command is missing,
> necessary to create a basin map. Did it disappear in the recent version,
> or is it just a flaw in the precompiled macOS X version?
It was disabled on 2002/01/04 and re-enabled on 2002/01/24; pre3
corresponds to 2002/01/16, so it was disabled in pre3.
Glynn Clements <glynn.clements at virgin.net>
