[GRASSLIST:3716] Grass 5.0.0pre4 RPMs for Mandrake 8.2
Buchan Milne bgmilne at cae.co.za
Wed May 22 12:59:18 EDT 2002
Hi all,
Since I had to get grass running for another student, I decided it would
be more worthwile, and probably faster, to build RPMs of grass.
Thus, I had put RPMs of pre3 in the Mandrake cooker, and today I have
just finished updating them to pre4.
Currently there is just one RPM for grass, and it is built with
PostgreSQL, lapack, gdal support, and nvis. You should only need the
RPMs in the following directory.
http://ranger.dnsalias.com/mandrake/mandrake8.2/grass/
You probably want just the following RPMs to run grass:
grass-5.0.0-0.pre4.1mdk.i586.rpm
libgdal1-1.1.7-1mdk.i586.rpm
To install, download the desired RPMs to an empty directory, and as
root, run:
# urpmi *.rpm
After installation, you should be able to run  grass5 from the
command-line, or start it from the menu
(->Applications-Sciences->Geosciences).
The RPMs are signed with my GPG key, which can be found at
http://ranger.dnsalias.com/bgmilne.asc (sorry, my Mozilla's enigmail got
removed on upgrade, so this mail isn't signed ...)
Please note that, due to the fact that I am building on my machine which
uses the NVidia binary drivers, that there is a false dependency on
libGLcore.so.1. If you are installing, and that is the only dependency
that is not resolved, you should add the --nodeps option.
I would appreciate feedback on the RPMS, especially from experienced
grass users on Mandrake 8.2
I will be putting these into the Mandrake cooker as soon as possible, so
there should be a working grass in the contribs of the next Mandrake
release. I hope to split grass into a few subpackages for the next release.
Regards,
Buchan
|----------------Registered Linux User #182071-----------------|
Buchan Milne                Mechanical Engineer, Network Manager
Cellphone * Work            +27 82 472 2231 * +27 21 8828820x202
Stellenbosch Automotive Engineering         http://www.cae.co.za
GPG Key                   http://ranger.dnsalias.com/bgmilne.asc
1024D/60D204A7 2919 E232 5610 A038 87B1 72D6 AC92 BA50 60D2 04A7
