[GRASSLIST:3754] Re: ARC/INFO Coverage files.
Markus Neteler neteler at itc.it
Sat May 25 13:22:32 EDT 2002
On Sat, May 25, 2002 at 07:31:47AM -0400, Ben Logan wrote:
> Hello,
> I have some ARC/INFO Coverage files I would really like to use with
> GRASS.  Is there any way to do so?  (Btw, the data providers are
> apparently not willing to provide the data in any other format.)
> Thanks,
Hi Ben,
to some extend 'r.in.gdal' should do the job. The trick is to
specify the *directory*, not a filename (why? I don't know).
See also
http://grass.itc.it/gdp/html_grass5/import.html
-> EHdr (ESRI HDR)
http://www.remotesensing.org/gdal/frmt_various.html
Cheers
 Markus Neteler
