[GRASSLIST:4708] Re: maximum size of polygon
Eric G. Miller egm2 at jps.net
Fri Oct 11 11:25:01 EDT 2002
On Fri, Oct 11, 2002 at 10:47:48AM +0300, orkun wrote:
> hi
> is there a way (module or command) to calculate maximum size (length) of
> a polygons.
None that I'm aware of.  If I understand correctly, that could be a very
computationally expensive function.  You want something that will find
the maximum span across a polygon? A straight line length? or the
longest path taking the shortest route?
begin 664 .signature
M<F5L;&E-("Y'(&-I<D4@/G1E;BYS<&I`,FUG93P)"`@("`@("`@("`@("`@(
M"`@("`@("`@("`@("`@("`A%<FEC($<N($UI;&QE<B`\96=M,D!J<',N;F5T
"/@H`
end
