[GRASSLIST:4483] Re: how to generate high resolution image?
Glynn Clements glynn.clements at virgin.net
Thu Sep 12 14:25:32 EDT 2002
Victor Wren wrote:
> > Xueming Wu wrote:
> > > I cann't find any tool that can run under unix/linux and
> > > convert ps to wmf through the web. I tried to use "gs".
> > > And the image is better. But the size of image is too
> > > large.
> > > Any idea or suggestion?
> > Glynn Clements <glynn.clements at virgin.net>
> > It may be possible to use a "chain" of converters, e.g. convert
> > PostScript to PDF, then PDF to WMF. [I only mention WMF because it's
> > one of Microsoft's own formats; I have no idea what PowerPoint
> > actually accepts.]
> Powerpoint's support of vector formats is exceptionally poor. It
> does, at least as of Office '97, import EPS. As far as I'm aware,
> DXF is entirely unsupported. It does accept WPG (not very useful).
> If there are any converters out there for PostScript to EPS (does
> Ghostscript do this?) then Powerpoint can import it.
Ghostscript includes a shell script, ps2epsi, which generates EPS
files.
> It will only display the preview image, but it will print out from
> the vector image.
1. Presumably that is only the case when using a PostScript printer?
To do it for other printers would require a PostScript interpreter.
2. That doesn't help if he's using PowerPoint to drive a projector.
Do you know whether PowerPoint imports *any* vector formats? EPS
doesn't really count if it's only displaying the preview bitmap.
> Support for EPS is much better in the Mac version of Office
> (and always has been) but portability may suffer.
> I'm not sure what he's saying about the "size of the image" being
> too large. Is it creating too large a file, or is it too big for the
> page?
I presume that he meant file size.
> If the latter, it can just be dragged down to the correct size
> with no loss of detail (the whole advantage of a vector format). If
> the former, using EPS should help (WMF simulates curves via straight
> line segments -- boo hiss! -- which makes for much larger files, not
> to mention poor quality curves [EMF was supposed to fix this, but
> it's WORSE, supporting only circular curves, which is almost as
> useless as only supporting straight segments] -- though the presence
> of a bitmap preview in EPS will grow the filesize somewhat.)
That shouldn't be an issue here; GRASS vector maps don't use curves.
