[GRASSLIST:5939] Label files from .dxf
Kurt Springs ferret_bard at mac.com
Tue Apr 1 18:12:32 EST 2003
Hi folks,
New question.  Apparently, when I imported the .dxf file with v.in.dxf the
contour labels did not import into the vector files.  I also ran v.in.dxf3d.
That did seem to help.  The .dxf file does have data labels.  Is there a way
I can get those labels to apply to the map with out going in and doing it
manually?  This map has a lot of contours.
Kurt
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20030402/3afc214c/attachment.html
