[GRASSLIST:5919] Re: strange d.histogram mess-up and a question
Eric G. Miller egm2 at jps.net
Sun Mar 30 15:36:52 EST 2003
On Sun, Mar 30, 2003 at 09:26:12AM -0500, Andrew wrote:
> I have a strange problem and I was wondering if someone might have an
> insight...
> Symptoms: Invoke d.histogram with a selected monitor window set to the
> approriate region and STDOUT echoes
> "r.stats: nn%" where nn is the incremented percentage complete. When r.stats
> reaches 100% the next line reads "segmentation fault" and nothing is
> displayed in the monitor window.
Try attached get_stats.c file
  cd src/display/d.histogram/cmd
  mv get_stats.c get_stats.c.bak
  <save> get_stats.c
  gmake5 -i
I found a couple potential trouble spots, but I have no idea if they are
related to your problem.
> Unrelated question: What rules are applied to set the defaultcolor palette
> to a raster image? I would like to know if the yellow->blue->red palette set
> by default uses percentage of full scale, standard deviations or some other
> approach to setting the color scale.
Generally the rules are linear min<->max.  grey.eq is histogram
equalized.  If no color rules exist, the rainbow palette is used.
echo ">gra.fcw at 2ztr< eryyvZ .T pveR" | rot13 | reverse
Type: text/x-csrc
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20030330/a4d83663/get_stats.bin
