[GRASSLIST:2492] g.mremove for 5.7
francesco.pirotti francesco.pirotti at unipd.it
Fri Feb 6 03:20:57 EST 2004
Hello,
I did some work for adding parser support to some scripts for 5.7.  Marcus
Neteler asked me to work on g.mremove because it is quite handy.
I attach to this mail the script for 5.7... no need to recompile anything,
just copy it in your script directory ($GISBASE/scripts).
ATTENTION:  you can call it with g.mremove and in this case you get a GUI
which is fine BUT before deleting it asks you "are you sure?" and waits for
a yes or no answer... problem is that the GUI does not take user input at
that point, so you get stuck.  SOLUTION: either use the flag "force" by
selecting the button on the GUI, but then you don't have a second chance,
or run it from the terminal with - g.mremove rast='<whateveryourpatternis>'
Please test it and let me know if it works or if it has problems.
Ciao
At 02.40 06/02/2004 +0000, you wrote:
>Kirk R. Wythers wrote:
> > How does one use g.mremove. I have recompiled 5.3 and 5.7 after cvs up
> > -dP today, and thought that its use and syntax were similar to
> > g.remove. However, I am getting a "command not found" error when I
> > attempt to run is from the command line (g.mremove -help yields nothing
> > as well). Is g.mremove something separate or require some kind of
> > compile option?
>No, it's just a script (src/scripts/contrib/g.mremove).
>Were there any errors in error.log after compiling?
>Glynn Clements <glynn.clements at virgin.net>
>Incoming mail is certified Virus Free.
>Checked by AVG anti-virus system (http://www.grisoft.com).
>Version: 6.0.571 / Virus Database: 361 - Release Date: 26/01/2004
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20040206/fccd82bb/g.obj
Francesco Pirotti
CIRGEO -University of Padua
phone. 049 - 8272522
fax.  049-8272686
cel. 328-2126861
Outgoing mail is certified Virus Free.
