[GRASSLIST:2540] Re: build errors on r.le
Markus Neteler neteler at itc.it
Tue Feb 10 12:03:51 EST 2004
> Not a great week for getting the cvs build to work on my linux machine.
> This time it seems to be with r.le:
You have to run:
make mixclean
make mix
(better explained in INSTALL file).
because of directory changes today in 5.7 (which brings r.le to you).
At time you have two files in the same directory, which are
separated now into two directories in CVS to allow for compilation.
Markus Neteler
