[GRASSLIST:2546] Re: build errors on r.le
Glynn Clements glynn.clements at virgin.net
Tue Feb 10 15:06:39 EST 2004
chris at fonnesbeck.org wrote:
> Not a great week for getting the cvs build to work on my linux machine.
> This time it seems to be with r.le:
> gcc -rdynamic -L/usr/src/grass57_exp_2003_12_06/dist.i686-pc-linux-gnu/lib
>    -o
> /usr/src/grass57_exp_2003_12_06/dist.i686-pc-linux-gnu/etc/bin/cmd/poly_to_bmif
> OBJ.i686-pc-linux-gnu/bmf_to_cll.o OBJ.i686-pc-linux-gnu/do_dots.o
> OBJ.i686-pc-linux-gnu/do_line.o OBJ.i686-pc-linux-gnu/find_area.o
> OBJ.i686-pc-linux-gnu/ply_t_bmif.o OBJ.i686-pc-linux-gnu/save_area.o
> OBJ.i686-pc-linux-gnu/wrte_recrd.o OBJ.i686-pc-linux-gnu/yadjust.o
> -lgrass_gis -lgrass_datetime   -lm  -lz
> OBJ.i686-pc-linux-gnu/ply_t_bmif.o: In function `main':
> /usr/src/grass57_exp_2003_12_06/raster/r.le/r.le.setup/polytocell/ply_t_bmif.c(.text+0x0):
> multiple definition of `main'
> OBJ.i686-pc-linux-gnu/bmf_to_cll.o(.text+0x0):/usr/src/grass57_exp_2003_12_06/raster/r.le/r.le.setup/polytocell/bmf_to_cll.c:
> first defined here
I haven't actually checked, but this looks like another case of 5.7
and 5.3 being out of sync. Either because the two versions aren't
compatible, or possibly because 5.7 needs "make mixclean mix".
Glynn Clements <glynn.clements at virgin.net>
