[GRASSLIST:2553] Re: Moire effect in aspect map
Tue Feb 10 22:21:01 EST 2004
well, the problem seems to be the data doesn't match the region info,
regardless of what "prj.adf" says.
Maybe 'gdalinfo' will give you a better idea of what the data details
are. It must be stored as rows and columns in the input file, all you
have to do is match that..
also, try 'r.in.gdal -e' and see if that does it.
Hamish
