[GRASSLIST:2196] Re: d.mon socket problem
Roger Bivand Roger.Bivand at nhh.no
Mon Jan 12 15:29:24 EST 2004
On Mon, 12 Jan 2004, Ben Logan wrote:
> On Mon, Jan 12, 2004 at 11:27:36AM -0600, William K wrote:
> > make sure you have the DISPLAY environment var set to :0.0
> > also make sure X11 is already running, if you're running GRASS from the
> > Terminal instead of an X11 xterm.
> > On Jan 12, 2004, at 10:16 AM, David Orme wrote:
> > >Hi,
> > >I've got grass57 built now - thanks to everyone. When I try and start
> > >a graphics monitor i get the following (most recent weekly snapshot,
> > >Mac OS 10.2.8):
> > >>GRASS
> > >>5.7.-cvs:/usr/local/src/grass57_exp_2004_01_10/bin.powerpc-apple-
> > >>darwin6.8 > d.mon start=x0
> > >>ERROR: Graph_Set: can't open Display
> > >>No socket to connect to for monitor <x0>.
> > >>Problem selecting x0. Will try once more
> David,
> I don't know anything about the Mac OS, but my understanding is that
> it is very unixish.  If that's true, in addition to William's
> suggestions, you might make sure you have permission to write to
> wherever GRASS is trying to create the sockets.  For example, on my
> Linux box, sockets for user "ben" are created in /tmp/grass-ben.  If
> "ben" didn't have write permissions on /tmp, no socket(s) could be
> created.
There has been discussion on this recently on the R list. While OSX is
close to Unix, it isn't always right to think Unix means X. R users have
found that OSX will only sometimes set DISPLAY (so causing graphics output
to fail when needing a running X server - Apple provides alternatives I
think). The cases were predictable. Google "R" gets you to R, R-help
mailing list archives.
Roger
> Regards,
> Ben
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
e-mail: Roger.Bivand at nhh.no
